Home > General > Airbag Light on constantly . any clues how to switch it off?
nic
Hi, i come cap in hand yet again
i have a 56 plate RRS hse and the airbag light is constantly on .. i have tried re-setting the switch on the passenger side and i have also changed the fuse but despite initially going out it came back on again within a matter of seconds
any clues on how to get rid of it ?
thanks alot
Post #284650 Mon Jan 03 2011 9:57pm
BIG DJ
The airbag warning light in the rev counter???
Post #284657 Mon Jan 03 2011 10:30pm
Bobby
any fault codes? Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #284671 Tue Jan 04 2011 4:03am
simon1233
Sounds like a trip to the dealer is in order. When the airbag light on mine was on (intermittently - like all the best electrical faults Big Cry ) it was eventually traced to a faulty crash sensor!?!
Post #285063 Thu Jan 06 2011 7:56pm
scarey
sounds like the occupancy sensor has a fault..replace this and the light will go out..
Post #285111 Fri Jan 07 2011 11:17am
nic
yep ,light on the rev counter .. vry annoying ..sounds like a trip to the stealer ... cheers guys
Post #285178 Fri Jan 07 2011 11:54pm
SkyWalker
Netherlands 2005 Range Rover Sport TDV6 HSE Buckingham Blue
Hi Nic,
what was the fault at the end?
How much did you pay to get it fixed?
Mine airbag light came on twice this week... Neutral SW
Sometimes it is not enough to do our best;
sometimes we must do what is required.
Adriatic Blue 2005 RRS HSE 2.7 TDV6
Now: 2016 RRS HSE DYNAMIC 3.0 TDV6
Post #312574 Mon Sep 05 2011 9:47am
Whistle RRS gone
Post #312575 Mon Sep 05 2011 9:50am
GAC23
2006 Range Rover Sport TDV6 HSE Zermatt Silver
Re: Airbag Light on constantly . any clues how to switch it
Possibly a daft question ...
But what is the
Post #369428 Tue Jan 15 2013 10:23am
he probably means the isolator switch for if you have a small child in the front. (disables the passenger airbag)
It's located on the end of the dash molding and is a slot you can turn with the ignition key.
You can just see it here
 RRS gone
Post #369431 Tue Jan 15 2013 10:28am
GAC23
Ah - of course!
Thank you. I'll give that a whirl before ringing the dealer.
Post #369433 Tue Jan 15 2013 10:31am
BigCat8810
United Kingdom 2008 Range Rover Sport TDV8 HSE Santorini Black
I had the same issue in an old P38 I had, the vehicle went into a main agent (a very poor one I have to admit) and came back with the same issue, they told me they had spent many hours trying to resolve and had been unable to do so.
I ended up finding out it was a common issue (via a Rangie forum), which was a lose connection under the drivers seat, which I sorted myself.
However, I am told trying to fix anything airbag related is not recommended due to the potential of the system discharging which can be dangerous. That said it was the only way I could resolve the matter at the time. --------------------------------------------------------
RRS TDV8 Black/Black (Gone)
RRS TDV8 Stornaway (Gone)
RR Vogue TDV8 (Gone)
RRS 4.4V8 (Gone)
Defender 110 300tdi (Stolen, much missed)
RR Vogue V8 P38 (Gone)
LR 90 TD (Gone)
Post #369456 Tue Jan 15 2013 2:25pm
GAC23
Thanks for the tip.
I took it to my local dealer earlier to ask them to read the fault code.
They were rammed full so couldn't.
But the chap that runs their Service Dept. asked if the seats have been moved.
I told him the car was recently cleaned and he said to check these wires too.
Post #369462 Tue Jan 15 2013 3:28pm
GAC23
Looks like it was a dodgy connection under the seat.
All sorted now - phew.
Over the last few days when it's been really cold I've had another 'Suspension Fault'.
Got it when running front & rear heated screens, the heated seats.
My guess was the battery and it was. Which is kind of good I guess - cheaper than the suspension anyway Smile
Thanks to all for their help.
Post #370501 Tue Jan 22 2013 2:43pm
