![]() | Home > Tips & Tricks > Cleaning your wheels |
Misery Member Since: 07 Dec 2005 Location: Waiting for L405 Posts: 2555 ![]() ![]() |
Been using that for ages Nick, very good stuff. |
Vadim Member Since: 20 Apr 2010 Location: London Posts: 855 ![]() ![]() ![]() |
Thank you for the info. Will definitely try it. Nick, did you sort out your radio? Vadim A. |
npinks Site Moderator Member Since: 26 Nov 2007 Location: Watching Posts: 6716 ![]() ![]() |
I use it too, diluted right down, but even neat its not good on burnt on dust though, you'll need something stronger for that
Tboner Member Since: 03 Dec 2008 Location: Bucks - UK Posts: 447 ![]() ![]() |
Bilberry good for a weekly clean , Virasol if you miss a couple of weeks 2014 5.0SC AB
kelley07 Member Since: 22 Jun 2010 Location: wales Posts: 45 ![]() ![]() ![]() |
Hi - Sorry to ambush your post - On two of my wheels i got what looks like fine rust in some of the corners - The wheels were like this when i bought the car. Thought i would be able to wash it off - But after loads of washes it still there - Any advise on how to remove it - What is the best solution to use - Cheers Mark. |
Sounds like iron deposits from brakes, or it could be a failed lacquer
Thanks Npinks - With the look of it in the corners i believe it is iron deposit. I googled iron cut and it came back as Iron X - Looks like the same stuff with the right up - Will order some soon - Thanks very much - Mark. |
No problems, I think it's the same stuff, going to buy myself some next year too
Just note that some of these cleaners soften the lacquer and allow the dirt particles that were hot when they stuck to the wheel's finishing coat to be dislodged.
redrover Member Since: 22 Jun 2007 Location: Sydney Posts: 94 ![]() ![]() ![]() |
Does anyone know if you can get iron x in australia? TDV6, MYO7 Java with Ivory leather, 19 inch wheels |
Not sure myself
panda Member Since: 17 Jan 2010 Location: london Posts: 702 ![]() ![]() |
Think you can still get XXXX |
![]() Hate the stuff, but haven't tried it on the wheels... TDV6, MYO7 Java with Ivory leather, 19 inch wheels |
SkyWalker Member Since: 04 Sep 2009 Location: Marbella Posts: 540 ![]() ![]() ![]() |
test. SW
