Home > Maintenance & Modifications > lower links
iz6byo
2006 Range Rover Sport TDV6 HSE Buckingham Blue
lower links
i found this on Ebay:
http://cgi.ebay.com/ebaymotors/Range-Rover...353wt_1167
what do you think about?
i saw on youtube.very easy to fit..... Very Happy
Post #283491 Sun Dec 19 2010 7:08pm
Tboner
loads of posts on this sort of stuff " see lowering suspension and modules " on the forum 2014 5.0SC AB
Gone 5.0 SC
Post #283510 Sun Dec 19 2010 9:09pm
chris mc
Scotland 2011 Range Rover Sport TDV8 Autobiography Stornoway Grey
Re: lower links
I am selling a set for £100, done less than 500 miles.
Post #283539 Mon Dec 20 2010 9:01am
iz6byo
hi Chris..
are there any problems when you go on access or offroad mode?
i mean the links reduce the high about 1-2 cm,maybe sould be a wrong setting for computer.
thanks
Post #283718 Tue Dec 21 2010 5:16pm
chris mc
iz6byo wrote:
hi Chris..
thanks
I had no problems what so ever with them i was still able to raise the car. They are also fully adjustable the ones i have are fitted with locking nuts too so that there is no chance of the links loosening off etc
Post #283721 Tue Dec 21 2010 5:53pm
ciaa
United Arab Emirates 2006 Range Rover Sport Supercharged Java Black
iz6byo,
I put these on mine and took them of again after a week, the ride was dreadful and I only had them set to 1" lower. Also you cant use access mode, as the car bottoms out and goes into extended mode, higher than off road!
I wouldnt waste your money Wink 2006 RRS Supercharged
Hawke Saker 22" rims Nitto Tires
Larini exhaust System
ECU remap
Modified and ported supercharger with 3lb pulley
Post #283722 Tue Dec 21 2010 5:55pm
iz6byo
hi ciaa
thanks for you answer.
thanks for your advice too..... Laughing
ciao
Post #283752 Tue Dec 21 2010 8:48pm
