Home > Maintenance & Modifications > Dealer Prices for Brakes - OMG !!!
twozzie
United States 2006 Range Rover Sport 4.4 V8 HSE Bonatti Grey
So I just had the $60k service on my 2006 and it cost me a little under $700 here in California. The service guy says I need new pads as they are"nearing" the limit and quoted me $1700 (I assume this is for the pads and rotors)
My local brake place quoted $1400 for pads, rotors, sensors, fluid and 3 year warranty.
I assume sensors in the front only - yes?
Post #283132 Wed Dec 15 2010 9:00pm
JimboTD5
England 2008 Range Rover Sport TDV6 S Buckingham Blue
Hi Twozzie
I believe the sensors are fitted to the front and rear but only on one side, on the basis that if one side requires changing the other side will as well!!
Jim
Post #283140 Wed Dec 15 2010 10:09pm
MAW
Sensors to front left and rear right IIRC - DIY pads in around 1-2hours - OEM parts off Ebay Thumbs Up
Post #283154 Thu Dec 16 2010 6:59am
leedsunited
United Kingdom 2008 Range Rover Sport TDV6 HSE Java Black
New rears being fitted tommorow at local independant, i am supplying LR pads and sensor cable, £40 + VAT Thumbs Up
Post #283204 Thu Dec 16 2010 4:49pm
Rislar
Have you got a link to the suppliers chaps, the ones ive found are rather expensive Sad If it aint broke leave it!
MY 18, Autobiography
MY 05, 07, 10,
Post #283220 Fri Dec 17 2010 12:12am
leedsunited
Rislar - What are you looking for fronts or rears, i have a new set of both in my garage, the fronts are standard part and not Brembo may be able to help you out Thumbs Up
Post #283231 Fri Dec 17 2010 11:58am
MAW
There are two LR main dealers flogging OEM parts on fleabay for £40-£50 ish (F/R) Brembo also up there but didn't remember their prices
Post #283245 Fri Dec 17 2010 2:31pm
