![]() | Home > General > Heated Windscreen!!!!!!! |
wackyjim Member Since: 12 Nov 2009 Location: Tayside Posts: 265 ![]() ![]() |
The automatic function of the heated windscreen is driving me mad...I appreciate it first thing in the morning when its frosty but it tends to come on all through the day when the outside temp drops below 3 degrees even though I try to switch it off it just keeps coming back on again |
Its easy to tell thats its on because of the shimmer that it causes...I have no idea why there is no light on the switch, there is first thing when you start the car or if you press the rapid defrost button but once that goes off it seems to have a mind of its own without lighting up the switch!!!..Air-con set at auto at 20 degrees which is more than warm enough I would have thought |
x5pea Member Since: 03 May 2007 Location: Lanarkshire Posts: 2097 ![]() ![]() ![]() |
ill be honest mate i didnt even notice it was automatic, ive never noticed mine coming on unless i click the button and i have seriously relished it each year when its frosty |
Old Stager Member Since: 12 May 2010 Location: Staffordshire Posts: 120 ![]() ![]() ![]() |
I think you'll find the shimmer is actually the heating elements themselves - you can see them in certain light conditions e.g. direct sunlight whether or not the heated front screen is switched on. I've got just the same effect on my Focus RS which also had a heated screen (but it doesn't come on automatically at low temp). I agree it is a bit off-putting, but out-weighed by the benefits of the heated screen IMHO 14.5MY SDV6 HSE Dynamic Indus silver/lunar/ebony 20" wheels, InControl, full-size spare, electric tow bar, adaptive xenons, adaptive cruise control, auto main beam assist. Gone: TDV8 HSE; Zermatt silver/ebony, 19" off road alloys, active diff, particle filter, tow pack (it was fun) BMW 730D SE (great car, sadly missed). Ford Focus RS mk2, Ultimate green, lux pack 2, bluetooth. The start of my mid-life crisis. IN THE GARAGE: BMW i8 - the mid-life crisis continues and it's great fun. |
Thanks Old Stager...Strange why this problem of shimmer only happens when the outside temp is as cold as it has been over the past few days...I'm absolutely convinced that the windscreen heating is on despite the switch light being off!!!! |
RichardM Member Since: 25 Sep 2009 Location: Herts Posts: 745 ![]() ![]() |
Just feel the top of the screen when you think it's on. If the heated screen has been on for more than a couple of minutes it will feel warm to the touch.
XRM Member Since: 30 Jan 2007 Location: Worldwide Posts: 26 ![]() ![]() ![]() |
Windscreen haze
lespes Member Since: 16 Jun 2008 Location: Channel Islands Posts: 1052 ![]() ![]() ![]() |
One simple way to test /find out remove fuse for windscreen heater.
bradtarga34 Member Since: 19 Jan 2010 Location: Walton-on-Thames Posts: 147 ![]() |
I actually noticed this for the first time today, thought it was the screen being on, as it turns on automatically as you know below I think 5 degrees, but no light showing to say it was on... Very odd, just had another Jamesons and seemed fine then, J
Tboner Member Since: 03 Dec 2008 Location: Bucks - UK Posts: 447 ![]() ![]() |
Haze is on all cars with the hi speed heated screen that i have and only shows when its very cold and sunny.
shuzzy Member Since: 02 Aug 2009 Location: West Yorkshire Posts: 143 ![]() ![]() ![]() |
I wish my heated screen would just work properly. I can turn it on and it can be nearly 10 minutes before it clears the frost to a reasonable level. My passenger side clears up reasonable but the driver side will still have several vertical lines of frost as if some of the elements aren't working. I just find myself scraping the old fashion way, which somewhat defeats the point of it being heated. |
Bradders Member Since: 08 Oct 2009 Location: Leeds Posts: 2515 ![]() ![]() |
@Shuzzy - sounds like you've some broken elements in the screen. My wife's Ka came like this when new and the screen was replaced at the first service under warranty. FF 4.4 V8 Soooo looking forward to this bad boy
