Home > Maintenance & Modifications > 2010 LED Rears on a 2005 RRS - What resistors and how to?
chris mc
Scotland 2011 Range Rover Sport TDV8 Autobiography Stornoway Grey
Martin wrote:
As I said the resistor required is not being used in the way you're thinking - the 2010 LED lamps are 12V supply assemblies.
The issue is not powering the LEDs themselves, they will work fine as "plug and play" on pre-2010, but with 2010 rear lamps fitted the pre-2010 body controller doesn't see sufficient current being drawn by the rear lamps, so assumes a bulb has failed. It then flashes the indicator lamp on the instrument cluster at double speed as a warning.
A high wattage resistor is fitted in parallel to simulate a bulb and "fool" the body controller, returning the warning lamp to the correct speed.
See my link to the DISCO3 wiki for more info.
I stand corrected then lol Embarassed
Having looked at the how to though i would advise against fitting resistors of any form onto carpeted areas as they tend to heat up a fair bit.
Thanks Martin i now see where you are coming from and i totally agree with the installation method. Parallel.
Post #280927 Tue Nov 23 2010 3:28pm
RRS PIMP
Check out this thread and have a look at my gallery for a few pictures, might help.
http://www.rrsport.co.uk/forum/post265931.html#265931
Post #282503 Thu Dec 09 2010 12:57pm
Davidch
Cant see your Gallery, but am sure I have seen your gallery before??? Confused RRS Supercharged
HST Body Kit, 2010 Rear Lights, Fully Colour coded, 22 Rinspeed's
Post #346583 Mon Jun 11 2012 1:19pm
