Home > Maintenance & Modifications > Stainless steel pedal fitment
funnyguy1
United States 2009 Range Rover Sport 4.4 V8 HSE Santorini Black
Has anyone installed the LR stainless ateel pedal set? The gas and brake pedal fitment just requires
drilling 2 holes in each pedal and attaching with screws to back, but the footrest piece looks like requires
you to get behind/underneath it to attach the screws and there does not appear to be a way to remove/release
the footrest itself. Thx in advance! Mike mike murphy
Post #282355 Wed Dec 08 2010 3:35pm
globe195
United Kingdom 2006 Range Rover Sport TDV6 HSE Bonatti Grey
Hi, You don't have to remove the whole footrest ,it's just the top part of it (a bit like a top on a box) You just need a flat bladed screwdriver or similar to prise the top off which sits inside the recess and then you will have access to the front/back to allow you to drill the two holes. Be very careful not to overtighten the nuts as you may shear the bolts off like I did? Laughing They look great when fitted. Thumbs Up
Post #282493 Thu Dec 09 2010 10:11am
will_wonka
Location: Tminus 12 months for the RS Sport Supercharged!!
.......you could always use a bit of 4x2......PM Misery, he has the method Whistle Whistle Wink L322 Big Daddy SUPERCHARGED 5.0 Autobiography - Here & Now!
5 series for the miles Smile
RRS S/C factory built HST - Gone
45 others have been and gone!
Post #282501 Thu Dec 09 2010 11:52am
