Home > Technical > Rear door will not unlock!!!
kevinlagan
Northern Ireland 2005 Range Rover Sport TDV6 HSE Java Black
As per above... Went to unlock and open the other day and nothing! Does anyone have any ideas? As always, any advice is most appreciated!
Post #282140 Mon Dec 06 2010 8:18pm
RRSTDV8DK
Denmark 2007 Range Rover Sport TDV8 HSE Stornoway Grey
I had the problem on left front door - it was under warranty and they replaced the whole unit.
Then I had it on the left rear door, no warranty anymore. Left it alone and it started to work again after a few days, then a bit unstable for a couple of weeks and now been working for months without any problems. Didn't think about it anymore until I saw your post.
Try this - Lock the car, then pool and hold the lever while you press open on the key fob. This should unlock the door.
It is most likely a loose connection to the central lock RRS TDV8 HSE in Stornoway Grey/Alpaca/Rhodium/Multimedia/Privacy Glass
Post #282285 Tue Dec 07 2010 10:51pm
