Home > Technical > only two weeks old and problems
Zilch
Australia 2010 Range Rover Sport 3.0 TDV6 HSE Fuji White
I hope this is a battery / power related issue, but its only 2 weeks old now and it is starting to light up like a xmas tree
An intermittent fault, but LR Customer Care want it "flat bedded" to the nearest Dealership (3 hours)..
New warnings include now "Suspension Fault"
Anyone had similar ills with theirs Confused:
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Another Pommie Bar Steward down under
MY20 Defender 110 SE P400 Eiger/Ebony
MY10 3.0 RRS TDv6 Fuji/Ebony/Anigre
Post #282182 Tue Dec 07 2010 12:47am
BKHK
Glad I wasn't "tempted" during the recent service to wander into the showroom.
Document it all Zilch and send Mr Cook a snottogram. That is disgraceful for a new car. Gone - 2008 Stornoway Grey RRS 2.7 TDV6
Post #282186 Tue Dec 07 2010 4:56am
Zilch
I am doing, the hire car form says for 2 weeks Shocked if thats the case they can replace the Rangie then with another, not the fecking Camry on the drive Evil or Very Mad Another Pommie Bar Steward down under
Post #282187 Tue Dec 07 2010 5:16am
Zilch
what does a 2 week old Sport look like
Well as a longish term owner i should have known Mad Scarey thing from the dealer, "LR have another one with the same build date and fault, they are hoping we can narrow it down on yours" Censored
Rolling with laughter Big Cry Rolling with laughter :blub:
Post #282190 Tue Dec 07 2010 7:07am
wackyjim
Scotland
Zilch...been where you are several times during the past 8 months, nothing more embarrassing than seeing a brand new car on the back of a breakdown vehicle not once but twice!!!! Evil or Very Mad Evil or Very Mad Evil or Very Mad
Your problems if not software issues could be a dodgy battery terminal( It was in my case but took the dealer 3 days to discover!!!!!!!!) I also had a fuel pump and injectors replaced after a major leak which almost resulted in the car bursting in to flames....Ohh almost forgot its going back to the dealers today because the air con/heater has packed up and its minus 8 this morning!!! Censored Censored
Post #282193 Tue Dec 07 2010 7:39am
2nd Rower
Australia 2008 Range Rover Sport TDV6 HSE Chawton White
No good Zilch, sorry to read about this..
Make sure you post a link in the Aussie section as a few do not read outside that section, and they may be looking for info.
As BKHK says.. record all your communications and the actions!
Post #282202 Tue Dec 07 2010 9:11am
Tboner
Had exactly the same on mine with a cascade effect
Its was a loose inter-cooler pipe !! which caused the fault which then tells all the other ECu's its got a problem
Mine was after 2-3 weeks as well
If it is that on yours then make sure the pipe is changed as it will have split with the back pressure. 2014 5.0SC AB
Gone 5.0 SC
Post #282206 Tue Dec 07 2010 9:25am
Zilch
2nd i will do, log will be started.. So far today i had LR Customer Care, the Townsville dealer, RACQ to recover it all on the phone.. lot of conversations to note
WJ, interesting enough speaking to the dealer that supplied it they stated that one thing that had not done on mine was they had not provided a modified cable which could cause some issues around power output, also they suspected possibly a faulty battery, i will ping that on an email to the dealer fixing it along with your observation
Cheers Jim Another Pommie Bar Steward down under
Post #282208 Tue Dec 07 2010 9:30am
hydronic
Australia
Sad Zilch, that is a very sad photo of your RRS on the truck and it makes me feel a tad nervous. Hopefully they will have learnt a little from 2nd about how to treat stuff like this. eternal optimism!!
Oh and shouldn't your sig say
3.0 TDv6 Fuji/Ebony/Anigre, locking Diff thingy, Towpack, sunroof, rear camera, high beam assist and a very brand new $25 Supercheap Auto cargo net... GONE.
Sorry, couldn't resist. Good luck with it.
Post #282215 Tue Dec 07 2010 10:53am
Jimmy Salsa
Australia
Hey Zilch - that's unforgiveable of the dealer to not have done the replacement for a known fault.
Need to see if you can get hold of any official tech bulletin from someone inside a dealership notifying dealers of the problem and the required fix.
If it does in fact exist, you have every right to make a claim for all costs incurred for the duration of the time you are without the car.
Good luck buddy 'Black Betty' Java Black RRS 07 TDV6
Post #282298 Wed Dec 08 2010 12:49am
Zilch
i think that is where Bobby comes in Thumbs Up
Bobby were you aware of any TSB's on modified Starter motor/battery cables, which could contribute to power fluctuation Thumbs Up
Tboner thanks for the heads up and i will also point my local dealer to your point.. Another Pommie Bar Steward down under
Post #282302 Wed Dec 08 2010 1:04am
Zilch
Thursday update
well apparently it is being delivered back at about 7 am tomorrow morning. According to the dealer they have changed one of the power cables, which should have been done as part of a recall/TSB/mod before the vehicle left the show room/ dealer.
Since the change they have been unable to replicate the problem or fault codes. That said as it was an "intermittent" problem then there is no guarantee Rolling Eyes
Hopefully i will be able to dump the Camry tomorrow
Post #282471 Thu Dec 09 2010 6:48am
Zilch
Recovered Again - 6 weeks old and 2 recoveries later
The problem returned within a week or so, it was intermittent, but then became progressively worse that it is guaranteed to happen within 15 minutes of driving the vehicle, Wife had to have it recovered to Northern Queesnland yesterday..
The warnings are "safety systems" related, ABS, Stabiity Control, Emergency Brake Assist etc, that in my eyes makes the vehicle inherently dangerous, if they do not fix it this time around, i am going to insist LR replace it with a new one, or i will return it, ask for my money back and walk away.. just speaking to the lease company now to find out what my options are.. Another Pommie Bar Steward down under
Post #285617 Tue Jan 11 2011 9:49pm
2nd Rower
Zilch, sorry to hear this... This is absolutely shocking for such a new car! And that (again) LR claim to have fixed it!
You have mail!
2R
Post #285622 Tue Jan 11 2011 10:19pm
Tboner
does it lose all power when this happens ? 2014 5.0SC AB
Gone 5.0 SC
Post #285628 Tue Jan 11 2011 11:51pm
