Home > Maintenance & Modifications > Polybush for ARB |
UK Guy Member Since: 28 Nov 2010 Location: Staffs Posts: 149 |
Has nobody fitted polybush in their Arb!
Sat Dec 04 2010 10:24am |
Sat Dec 04 2010 10:25am |
avos Member Since: 26 Aug 2008 Location: Belgium Posts: 106 |
Polybushes aren't new, so there must be a reason why they haven’t been used from the start with I would guess.
Sat Dec 04 2010 11:03am |
carlos50 Member Since: 04 Oct 2010 Location: North East Posts: 401 |
Polybushes badly affect the RRS ride from what ive read and in the ARB id assume the harder compound will transmit noise. Only an assumption though.
Sat Dec 04 2010 6:05pm |
I have seen them at
Sat Dec 04 2010 8:03pm |
JimboTD5 Member Since: 29 Jan 2010 Location: Hertfordshire Posts: 113 |
Hi UK Guy
Sat Dec 04 2010 9:30pm |
Jim
Sat Dec 04 2010 10:30pm |
I was advised by LR that they have re designed / improved the ARB bushes because of all the problems and have been quoted around £20 or so for supply of the new ones on the front.
Sun Dec 05 2010 5:49pm |
Just checked out the site and noticed clamps and mounts, did you get both and if so do you need to do both on the front and both on the rear ?. |
Sun Dec 05 2010 5:52pm |
No I just ordered the polybushes. Which clamps & mounts?
Sun Dec 05 2010 6:11pm |
In your link there are ARB mounts and ARB clamps, which are you doing ?. |
Sun Dec 05 2010 7:47pm |
I was lead to believe that one set was for the non ace (forgot what they call it on the rrs) and one was for ace (I've got non ace). The rrs with ace has different size than non ace.
Sun Dec 05 2010 8:14pm |
Did you have the polybushes fitted?. If so how have you found them so far? |
Tue Dec 14 2010 8:03am |
Hi
Tue Dec 14 2010 7:14pm |
