Home > Australia & New Zealand > UHF cable installation
640Newton
Australia 2008 Range Rover Sport TDV8 HSE Stornoway Grey
This is a question for people who have installed a 2-way UHF radio in their RRS.
Just curious to find out how people are routing the cables from the aerial into the car? Without a bull/nudge bar to mount the aerial to, my only option is to mount it to the roof rail track but I can't work out an obvious way to run the cables into the car.
Thanks,
640Newton 2008 TDV8, Stornoway Grey with Alpaca premium leather, Adaptive cruise, Adaptive Bi-xenons, sunroof, Premium Nav, Premium ICE Logic 7, telephone, active locking rear diff, console coolbox, seat memory, powerfold mirrors, tow pack, window tint, dual battery, engel fridge, Goodyear Mud-Terrain tyres.
Post #281560 Wed Dec 01 2010 1:33am
raadar
Australia
hiya 64
My solution is as follows:
I have mounted an inobtrusive CD930 antenna onto an aluminium L-bracket which passes thru a slot cut into the plastic skirt behind the bonnet on the passenger side, and this is then screwed to the vertical metal work behind....after a bit if minor twisting of the bracket. (when I sold the car I simply fitted a new skirt, which wasn't OTT $.)
The cable leads directly thru the firewall behind the centre console to the gme 3440 UHF which is fitted under the transmission cover plate next to the gear selector. The microphone, which contains all the operational controls, is mounted within the storage compartment under the armrest/lid. When the UHF is required I simply lead the microphone cable out from under this lid next to the latch and rest it on the centre console. The armrest/lid closes ok over the cable.
This arrangement means that the whole installation is out of sight until needed and the antenna does not look out of place on the vehicle. Although it is not a 1.5m yacht mast antenna, I find that its function is more than sattisfactory, and it can remain permanently on the car.
I can post a photo but you will need to advise me how to attach it.
regards...............frank
Post #281566 Wed Dec 01 2010 6:06am
640Newton
that sounds like an ideal setup Frank and I would love to see a photo or two. From memory you have to upload the photos to a site such a Photobucket and then post the image address into your message using the "Img" button before and after the image address.[/img] 2008 TDV8, Stornoway Grey with Alpaca premium leather, Adaptive cruise, Adaptive Bi-xenons, sunroof, Premium Nav, Premium ICE Logic 7, telephone, active locking rear diff, console coolbox, seat memory, powerfold mirrors, tow pack, window tint, dual battery, engel fridge, Goodyear Mud-Terrain tyres.
Post #281567 Wed Dec 01 2010 6:18am
raadar
Australia
64
attempt 95....here we go again
this shows position of antenna. I would have to photogragh the installation if you need more info. please advise and I will do
regards............frank
Post #281570 Wed Dec 01 2010 7:30am
640Newton
this might be a silly question, but in the obviously highly unlikely event of having to lift the bonnet, do you have to inscrew the aerial before you can do so? 2008 TDV8, Stornoway Grey with Alpaca premium leather, Adaptive cruise, Adaptive Bi-xenons, sunroof, Premium Nav, Premium ICE Logic 7, telephone, active locking rear diff, console coolbox, seat memory, powerfold mirrors, tow pack, window tint, dual battery, engel fridge, Goodyear Mud-Terrain tyres.
Post #281581 Wed Dec 01 2010 8:38am
raadar
Australia
640,
no, the aerial is positioned just behind the edge of the bonnet which operates on articulated hinges in a "forward slide" motion
Post #281688 Wed Dec 01 2010 10:51pm
Jimmy Salsa
Australia
Hey 640,
Had similar probs myself including one installation 'specialist' refusing to work on it wsying it was too complicated from someone who didn't know the car well.
Ended up getting the guys at All 4x4 in Newcastle to help me with it.
Solution was a custom bracket mounted passenger side and fed through the firewall at the back, then along behind the centre console. The head unit is actually mounted behind the kickplate beneath the steering wheel.
The only thing I found is that the speaker wasn't loud enough and I mounted a standard mini speaker above the mic.
Both mic and speaker mounts are held on with dbl sided tape so I can remove them without leaving any marks if/when I go to sell it.
Excuse the pic quality. Just raced out with my i-phone to shoot these.
 'Black Betty' Java Black RRS 07 TDV6
Post #281978 Sun Dec 05 2010 7:46am
640Newton
Thanks Jimmy, that looks like a neat setup. Can I assume from the photos that the bracket is welded in place?
I went to a 4WD shop in Hornsby the other day to ask for their advice and he made it pretty clear that he wasn't interested in trying to install anything on the car as it would be too hard. He even tried to quote me a very high hourly rate for installation so knowing that he wasn't interested in helping I thought I'd stir him up so I just said that was fine and I'd be happy to pay it; you should have seen the look on his face!!!
Anyway, that has certainly helped me with some ideas on how to do it. Thanks again. 2008 TDV8, Stornoway Grey with Alpaca premium leather, Adaptive cruise, Adaptive Bi-xenons, sunroof, Premium Nav, Premium ICE Logic 7, telephone, active locking rear diff, console coolbox, seat memory, powerfold mirrors, tow pack, window tint, dual battery, engel fridge, Goodyear Mud-Terrain tyres.
Post #282077 Mon Dec 06 2010 7:46am
ivery819
640
I have a spare one of these if you want it........PM me
Post #282086 Mon Dec 06 2010 11:36am
Jimmy Salsa
Australia
640
Whichever way you go with the mounting bracket, Would recommend you have it sprayed in same colour as your car to make it less noticeable. 'Black Betty' Java Black RRS 07 TDV6
Post #282300 Wed Dec 08 2010 12:51am
