Home > Technical > EGR Valve possible problems
Brennie
England 2005 Range Rover Sport TDV6 HSE Buckingham Blue
Hi has any one had problem with egr valve rrs 2005? Mine is smoking when started and lack of power are these related to egr valve any help much appreciated. cheers
Post #281321 Sun Nov 28 2010 5:54pm
EGRs on a car this age could well be a problem but you're likely to get an engine warning if there's a problem with them. Drop the car off to a dealer to check because it could be a number of things. 2005 Zambezi TDV6 - Gone but not forgotten
Post #281340 Sun Nov 28 2010 8:28pm
kupid0n
Romania 2006 Range Rover Sport TDV6 HSE Java Black
hey! had the same problem....does it smoke when you floor it?mine did....horribly....had a hole in the intercooler....replaced it.....problem solved, but a month later the hose between the intercooler and the intake just "exploded" causing the same problem....replaced that too and now it runs like a champ. have a mechanic check your intake pressure because black smoke and lack of power can mean only one thing....bad air/fuel mix.
Cheers mate!
Post #281419 Mon Nov 29 2010 10:01pm
Brennie
Hi kupidOn smokes when first started and when i'm driving it smokes when it changes gear there's a real lack of power momentarily. Thanks
Post #281422 Mon Nov 29 2010 10:40pm
Brennie
Result
Hi been to land rover main dealer today and N/S EGR valve is not working properly so glad its only that! But there is one thing will i run 2 stroke oil in it again i think not!!!! Rolling Eyes
Post #281872 Fri Dec 03 2010 9:57pm
