Home > Technical > Front Grill
kevinlagan
Northern Ireland 2005 Range Rover Sport TDV6 HSE Java Black
Front Grill
Guys,
Can the inner part of the front grill be separated from the outer part and, if so, is this difficult to do? As always, your comments are appreciated.
Thanks
Post #281240 Sat Nov 27 2010 3:36pm
Vadim
United Kingdom 2010 Range Rover Sport Supercharged Santorini Black
If I understand you correctly, then the procedure is described in the owner's book. It is easy, but you must be careful because it is made of plastic. Vadim A.
Post #281282 Sun Nov 28 2010 3:58am
Vadim
it is on page 76 Vadim A.
Post #281283 Sun Nov 28 2010 4:20am
kevinlagan
Thanks so much Vadim... Unfortunately I have misplaced that manual. I there an e-version that I could check online?
Post #281289 Sun Nov 28 2010 8:40am
Vadim
Sure, it is available online:
http://www.ownerinfo.landrover.com/extfree2viewlrprod/index.jsp Vadim A.
Post #281314 Sun Nov 28 2010 3:29pm
kevinlagan
Thanks... But it just tells me how to remove the grill. Can the silver insert be separated from the grey outer part? It looks like it but not 100% and don't want to break it. Thanks V fir the link, awesome resource!
Post #281339 Sun Nov 28 2010 7:27pm
