![]() | Home > General > Can someone speak to me if they have a Supercharged RRS LPG? |
Davidch Member Since: 22 Jul 2009 Location: Kent Posts: 40 ![]() ![]() |
I would also like to know, as I am booking mine in soon. RRS Supercharged HST Body Kit, 2010 Rear Lights, Fully Colour coded, 22 Rinspeed's |
Jonas & Jonas Member Since: 27 Oct 2010 Location: Harrogate Posts: 161 ![]() ![]() ![]() |
Well my vote is a whole lot of grief. |
caperbility Member Since: 14 Jan 2010 Location: landscaping the world Posts: 221 ![]() ![]() ![]() |
I rang a few people for costs with regards converting my 2005 RR SC to gas and all but one of them was not keen to do it due to glitches etc. Sort of Says it all in my opinion so i didnt bother. |
RonnieT Member Since: 02 Nov 2010 Location: Ireland Posts: 15 ![]() ![]() ![]() |
I have one.
I have heard some horror stories with regards the JLR V8's. According to one dealer, guy had his done engine blew, got replaced they advised him not to reconnect LPG conversion, he did naturally and after 2000 miles that engine also blew...................cost to him �16,000 with labour etc.
avos Member Since: 26 Aug 2008 Location: Belgium Posts: 106 ![]() |
Have no experience with LPG, but think it is not fully safe/developed yet for modern cars when you hear all the stories.
MikeS Member Since: 24 Dec 2009 Location: Parkdale, Melbourne Posts: 261 ![]() ![]() ![]() |
I have the normally aspirated 4.4 V8, running on LPG and it's fine. Having had a very long discussion with JE Engineering about the conversions (mine wasn't done by them, I just called in for a chat) I'd say that the S/C is a bit of a can of worms when it comes to LPG. JE will not do an LPG conversion on them without modifying the exhaust valves & guides, due to the excessive wear that the higher burn temperature of LPG introduces onto the exhaust guides. They may not even offer the conversion anymore. Others will install a flashlube system to get round this wear issue, personally I think that's a workaround, it's not a fix. They've also had a number of occurences with the LPG system firing off the engine management light and if you've just spent a shedload on the conversion, the last thing you then expect is for it to then run with the EML illuminated.
RoyDB9 Member Since: 17 Nov 2010 Location: High Wycombe Posts: 9 ![]() ![]() |
Thank you Mike for your very helpful input. There must be some more success stories out there, i have test driven one and it was faultless, just need to know if it was a lucky day or is it that it can work now and again? |
How long a run did you take it for ? I find with mine it'll sometimes illuminate the EML after a long motorway run if I then get stuck in slow traffic at the end of it, or if I'm just doing stop / start driving in a town so it's worth doing one of those just to see if the one you're thinking of displays the same traits. 3 cycles of the key and the light usually goes out. I've had the faults downloaded before now and it's always the same things, none of which are harming the engine, it's just the super sensitive sensors realising it's not running on petrol.
pawmaro Member Since: 16 Oct 2010 Location: Bristol Posts: 10 ![]() ![]() ![]() |
I have had LPG conversions on a X5 which was a cheap conversion massive drop in power a F150 5.4 ltr and a 5.4ltr supercharged with Prinz sytem which is fantastic. No loss of power and you wouldnt know if on petrol or lpg. If you are going down the lpg route pay the extra fo a Prinz system, well worth the extra . |
