Home > Technical > My Sport goes into extended mode every time access mode. |
Jimmy_75000 Member Since: 06 Oct 2006 Location: London, UK Posts: 1146 |
switch wrong way around???? Range Rover Vogue ‘17 TDV6
Mon Nov 15 2010 11:48am |
RonnieG Member Since: 16 Mar 2008 Location: Armagh Posts: 207 |
Lol no it was working a few weeks previously it is a fault somewhere |
Mon Nov 15 2010 12:22pm |
DSL Member Since: 17 May 2006 Location: Heelands/Cobham (delete as appropriate) Posts: 1045 |
Will do that if it thinks it's grounding, good way to trick a D3/RRS into extended height. Might be a fault with a height sensor. |
Mon Nov 15 2010 12:24pm |
it does not read a fault but she is dropping at the rear over night. annoying really!! |
Mon Nov 15 2010 6:41pm |
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 |
Agree - common - there was a recall out for this earlier this year for a batch of faulty sensors - but common symptom for a failed or failing sensor - LRA can diagnose and assist at home if still covered. |
Mon Nov 15 2010 6:57pm |
AG09 Member Since: 13 Mar 2010 Location: West Yorkshire Posts: 66 |
Ditto, Mine had the NSR sensor replaced for the same reason. As a temporary fix you can overcome it by locking it in access mode as soon as it bings to go into extended mode.
Mon Nov 15 2010 11:33pm |
I have a pic of mine when it did it - super extend at rear access at the front When I limped home with the fault it was like a flying carpet - all over the place raising and lowering |
Tue Nov 16 2010 6:22am |
! Any chance to post it on the forum? Range Rover Vogue ‘17 TDV6 Gone: Range Rover Vogue '11 4.4TDV8, Range Rover Sport ‘59, Range Rover Sport ‘56 |
Tue Nov 16 2010 7:39am |
Will dig it out and post |
Tue Nov 16 2010 10:42pm |
