Home > My Range Rover Sport > side steps
rexs
side steps
Are the aftermarket side steps as good as the genuine ones? which have you fitted and who supplied them? Many thanks rexs.
Post #280208 Sat Nov 13 2010 9:31pm
anthony-apl
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Fuji White
Don't waste your money on anything but the genuine ones mate. If your handy with a socket set you can fit then yourself too. I bought mine on fleabay and it took less than 2 hours for me to fit them. I've just removed them to re-fit on my new car when I get a chance. 16 model year yulong white autobiography
Bentley continental GTC
2011 VW Transporter T5 Kombi 140BHP with sport line kit for work
15 model year black RRS HSE gone
11MY Fuji White 3.0 TDV6 HSE
Ivory premium leather
Ebony contrast stitching
Extended leather pack
Anigra Wood now gone
08MY Range Rover Sport TDV6 GONE
Post #280209 Sat Nov 13 2010 9:38pm
NeilR
Agreed,
someone on here tried supplying me copies and passing them off a genuine, the brackets were clearly not to a landrover spec or quality, the step bit though was very good.
Genuine all day long.
N 2010 RRS TDV8 Overfinch GTS
Post #280213 Sat Nov 13 2010 10:14pm
carlos50
Any chance of some DIY instructions for fitting genuine steps please ?.
I have just bought a set of eBay and the LR instructions arent the best, some words of car / hints would be most welcomed. I need to cut the sills as the kit doesnt come with pre cut ones, what tool will i need ?.
Thanks
Carl
Post #280494 Wed Nov 17 2010 6:52pm
oldcro
Scotland
Landrover's instructions can be found at:-
Landrover.co.uk
Owners - servicing and maintenance
Handbooks and Owners
Take me to the owner information website (displayed in orange)
Select model RRS
Select year
Find
Owner
Accessory fitting instructions
Access.
Click on each in turn and there you are.
Post #280502 Wed Nov 17 2010 7:43pm
carlos50
I have read them and they arent the best to say the least.
Id hoped for better information from somebody who has done this and found out abut tips / hints etc.
Post #280503 Wed Nov 17 2010 7:45pm
JimboTD5
England 2008 Range Rover Sport TDV6 S Buckingham Blue
Hi Carlos
I recently fitted side steps to my RRS, I found the instructions quite good if you take it slowly and use them as you remove and re-fit the parts. I tried to read and understand the instructions from the comfort of my living room and found them quite difficult to understand.
The only tricky bit is cutting the old trim for re-use, I beleive the kits used to come with the plastic sill covers pre cut but that has now ceased and you have to re-use the old trim.
You should have a template for both sides in the kit which you tape to the old trim with masking tape prior to cutting, don't forget to measure twice and cut once!!
Good luck.
Jim
Post #280507 Wed Nov 17 2010 8:10pm
