Home > Technical > Number plate |
rexs Member Since: 25 Oct 2010 Location: Lincs Posts: 25 |
Please could anyone tell me how to remove the rear number plate. Thanks |
Fri Nov 12 2010 8:05pm |
Pull firmly but slowly from top left or top right corner. When one end is clear then proceed by allowing the old plate to bend and 'peel' from bodywork. |
Fri Nov 12 2010 8:45pm |
AlexMckie Member Since: 26 Nov 2009 Location: Devon Posts: 174 |
You could warm the plate with a hair dryer or heat gun on low setting.... Softens the glue on the foam.....
Sat Nov 13 2010 7:31am |
KR1005 Member Since: 03 May 2010 Location: Hong Kong Posts: 61 |
Get some fishing line and place it behind the plate and slowly cut through the back of the plate. The plate will come off without risk of breaking the it. |
Sat Nov 13 2010 7:33am |
