Home > Maintenance & Modifications > Which oil for TDV6? |
MrH Member Since: 16 Jan 2008 Location: Disco3 World Posts: 13 |
Try this http://www.disco3.co.uk/gallery/albums/use...20Oils.pdf
Wed Nov 10 2010 6:01pm |
BIG DJ Member Since: 25 Oct 2009 Location: Heathrow Posts: 816 |
Thanks mate but that doesn't give engine oil??? |
Wed Nov 10 2010 7:36pm |
Texstar Member Since: 27 Aug 2006 Location: W.London Posts: 208 |
I have used Castrol Magnatec 5w 30, for an interim oil change. This is also what my dealer uses. There are other makes of course, but you need to stick to the spec and viscosity quoted in the handbook. You'll need about 5.7 litres (from memory) RRS TDV8 Buck Blue (no, not now in my dreams). ..........D3 TDclankety clankV6 ............BMW 318i |
Wed Nov 10 2010 7:44pm |
DSL Member Since: 17 May 2006 Location: Heelands/Cobham (delete as appropriate) Posts: 1045 |
Use Ford 5w30, correct spec and got 20 ltrs cheap. Remember the engine is Ford built and Pug designed so Ford oil will be OK! Otherwise Halfords own brand 5w30 fits the spec. |
Wed Nov 10 2010 7:49pm |
Oh balls Sorry mate, I thought it covered the lot |
Wed Nov 10 2010 9:15pm |
2.7L TDV6
Thu Nov 11 2010 10:54am |
Fatandre Member Since: 05 Oct 2009 Location: Reykjavík Posts: 401 |
Since we are talking about oil, waht would you recommend for the supercharged? |
Thu Nov 11 2010 11:01am |
Thanks bobby.
Thu Nov 11 2010 10:13pm |
