![]() | Home > Maintenance & Modifications > RRS MY10 Tailpipes |
jonnyboy Member Since: 27 Aug 2010 Location: Geneva Posts: 10 ![]() |
will these pipes fitt 2007mod HSE TDV8 with original pipes facing down? |
JC1 Member Since: 24 Oct 2009 Location: Berkshire Posts: 939 ![]() ![]() ![]() |
Not sure if the bore of the exhaust is the same as v6, have a look on his web page in the sponsors list, dcc 4x4, if still not sure contact Martin a call at dcc4x4. ![]() Jeep 4.0 High Output XJ 94 6" teraflex lift, c/w rear coils, 9500lb winch, 35" TSL super swamper boggers, safari snorkel, custom made bumpers, tom woods custom double cardon driveshaft, twin electric fans. Don't follow it..............you wont make it. The first 4 x 4 by far. |
Jonny - Looks like these will fit
funnyguy1 Member Since: 18 Jun 2009 Location: Sun Valley Idaho Posts: 171 ![]() ![]() ![]() |
I just noticed an almost new pair of supercharged exhaust and tips for 80 lbs on the ebay.uk website. I had the tips mentioned here but the chrome flaked off in 4 months so put the SC packs on my HSE. They were welded on in 5 minutes!! mike murphy |
jezbot Member Since: 13 Jul 2010 Location: yorkshire Posts: 21 ![]() ![]() |
i'm after a set of these if you are still stuck with them. how are they secured to the vehicle? do they neeed welding on? |
merlin1 Member Since: 16 Sep 2009 Location: cornwall Posts: 110 ![]() ![]() |
Here are my new stainless exhaust trims for 2010 3.0 v6 with dpf looks the biss.
X4 Member Since: 16 Aug 2010 Location: Aberdeenshire Posts: 16 ![]() ![]() ![]() |
Fitted a set of these from DCC a few days ago but the offside would not slide on. I removed the inserts from both tail pipes and neither would fit the offside but both slid on neatly on the near side. Out came the Dremel and I split one insert, slid it on to the offside tail pipe then slid the trim on top and lined up the holes for the grub screws. Inserted the grub screws, positioned the trim and tightened everything up not forgetting the 2 lock nuts for the grub screws! Was a little concerned that splitting the insert would cause a rattle but all is well and the new trims look great and really smarten up the a**e end |
big pimp Member Since: 09 Jan 2010 Location: northern ireland Posts: 548 ![]() ![]() ![]() |
Oh my god Merlin - awesome!!! Where did you get them from and how much if you don't mind me asking? Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
I can supply more of these for £125 for a pair inc carriage mainland only ,they will only fit tdv6 3.0 with dpf straight tail pipes pm if interested . |
DJH Member Since: 17 Jun 2008 Location: Peterborough Posts: 91 ![]() ![]() ![]() |
Just got myself a set of these Hawke tips via Fleabay. Can't wait to get them on - waiting for the RRS to come back from colour coding this week!!! JC1 - Sorry to be thick but what's the "U" shaped bolt/ bracket that comes in the box for? RRS 3.0 SDV6 Autobiography Dynamic MY16 Firenze Red. BMW 520 M Sport Saloon Space Grey 2015 Silver Previous: RRS 3.0 TDV6 HSE 2010 Stornoway Grey RRS 2.7 TDV6 HSE 2007 Stornoway Grey - R.I.P. |
DJH - On my MY10 i had to do away with the inserts as they would not slide far enough over the exhaust to sit right, i then tightened the alan screws up to secure, there is an aluminium strip that you unfold pas under the u-clamp then fold back over and tighten clamp, just some extra security it think, hope that makes sense |
