Home > Technical > Is there a reset procedure for the S/C gearbox ?.
carlos50
Hi all
I want to drive my S/C in sport mode and its a bit jerky and changes gear at odd times which i assume is down to the learnt driving style of the last owner ?.
Anyway, on so many other cars there is a reset procedure (was key in pos 2 then accelerator to floor for 5 secs in my SL) is there a procedure to reset the gearbox on the S/C ?.
Thanks
Carl
Post #279176 Mon Nov 01 2010 12:53pm
Vadim
United Kingdom 2010 Range Rover Sport Supercharged Santorini Black
Hey bud,
What exactly do you mean by odd time? Can you give an example? Vadim A.
Post #279503 Thu Nov 04 2010 6:47pm
carlos50
Hi Vadim
For example i am driving along in sport mode (revs are a touch higher than normal as expected) and then the gearbox just kicks down a gear making the car surge a bit if you get what i mean. It can do this going in to / coming out of corners etc aswell. Its as if its not sure what its meant to do and my throttle responses are confusing it.
Its not a problem as such i just think its a bit jerky and erratic in its up and down shifts and i thought a reset to learn my driving style might help.
Changes are smooth etc just a but unexpected at times.
Do you know a procedure for resetting ?
Carl
Post #279531 Fri Nov 05 2010 8:22am
ELD70
I seem to recall that disconnecting the cars battery for a while sets the adaptive gear box back to its default settings. The auto box could need a fluid change which has been discussed a lot on the D3 site. One of the sponsors can do a mobile Mega Flush and a lot of D3's have been transformed afterwards.
Post #279600 Sat Nov 06 2010 10:46am
Vadim
I am not aware of such procedure, but I have heard the same about the fluid change. Not sure if it applies for RRS though. Vadim A.
Post #279601 Sat Nov 06 2010 10:50am
DSL
Should do, a RRS being a D3 in drag! Whistle Whistle Wink
Post #279602 Sat Nov 06 2010 10:53am
