Home > Technical > DVD Picture flickering/distorted with Rear Headrest TV's
allcdsrus
Hi, Just wondered if anyone has came across this before. When I load up a dvd (from the 6 disc changer - all standard LR equipment) it starts fine, picture and sound all ok however when you actually reach the DVD menu screen and click on Play the dvd loads and the screen has horixontal lines scrolling up and down distorting the area where the lines are. The screen then goes black and the picture comes back on and off repeatadly, like flickering on and off and the picture has still got lines all over it when it is on. Then it will play fine for a few seconds and repeat the same process. This is with Original DVD's and they are clean and not scratched. This occurs on both TV's but this problem is not seen at identical times on both TV's although it does happen on both.
Anyone seen this before? If so what was the issue?
This is all when the car is stationary and nothing to do with movement of the car.
Thanks in advance
G
Post #279155 Sun Oct 31 2010 11:05pm
Jimmy_75000
loose cable seems likely....but it's going to be hard work to locate it! Range Rover Vogue ‘17 TDV6
Gone: Range Rover Vogue '11 4.4TDV8, Range Rover Sport ‘59, Range Rover Sport ‘56
Post #279162 Mon Nov 01 2010 8:44am
allcdsrus
Thats what I was thinking....Ive got the wiring diagram so will take a look Smile
Post #279250 Tue Nov 02 2010 10:10am
allcdsrus
Thinking about it, im certain this is covered by my warranty so may as well just get them to do it for me ha ha
Post #279251 Tue Nov 02 2010 10:11am
Jimmy_75000
I had an issue with it recently... it was with the AUX entries.... AUX1 had mono sound only, AUX2 no sound and no picture...
Took the dealer (thank you Looker Park Royal) an extra day (car went in for annual service) to locate and reach the point where the cables where not properly plugged in... Range Rover Vogue ‘17 TDV6
Post #279254 Tue Nov 02 2010 10:24am
allcdsrus
thanks for that info, I may take a quick look before putting it into LR. I will advise of the outcome either way
Post #279286 Tue Nov 02 2010 3:00pm
