Home > Technical > Bonnet Catch - check it engages fully after opening! |
Renny Member Since: 01 Jun 2005 Location: Fife Posts: 21 |
I'd get it checked Tim. We had a similar problem with our last Tdi Discovery and ended up with a dent in the bonnet when I slammed it shut after the 6th time it blew open on the M90 heading home. Each time the safety catch held it but it was worrying.
Wed Jun 15 2005 2:27pm |
Autocar have had the same problem - but at much higher speed than I was doing |
Wed Jun 15 2005 2:32pm |
MDP Member Since: 14 Jun 2005 Location: Back in an AUDI Posts: 8598 |
Tim perhaps on your next trip to B&Q you may consider picking up a roll of Duck Tape...... ..affix it to your bonnet....... call into your dealer,looking extremely worried & bearing this weeks copy of Autocar ........this should do the trick.
Wed Jun 15 2005 3:03pm |
Biggles Member Since: 26 May 2005 Location: Preston, Posts: 916 |
Have you spoke to the dealer over this, if so what are they doing about the problem. Its out there somewhere. Second V10 Treg on the drive at the moment. |
Thu Jun 16 2005 8:09am |
Andrew Member Since: 16 Jun 2005 Location: Cheltenham Posts: 248 |
I have found the only way to close the bonnet successfully is to cringe as you slam it shut from about 6 to 8 inches high!! |
Sat Jun 25 2005 8:16pm |
Sounds about right Andrew! |
Sun Jun 26 2005 12:27pm |
Simon Member Since: 13 Jun 2005 Posts: 44 |
Same problem when I took delivery.
Mon Jun 27 2005 10:01am |
My old P38A developed a dint in the bonnet using the push gently method, some things never change Its out there somewhere. Second V10 Treg on the drive at the moment. |
Mon Jun 27 2005 11:33am |
Robbi Member Since: 14 Jun 2005 Location: Channel Islands, Guernsey Posts: 130 |
When I closed the bonnet on my dealer's demo I thought I had dented it after pressing down on it! It's quite soft.....aluminium I believe? And they say 4x4's are pedestrian unfriendly. |
Mon Jun 27 2005 2:43pm |
It happened again today despite slamming the bonnet pretty hard so drove along to the dealer and they adjusted the nearside catch while I waited, and then told me that nearly every car delivered by the dealer has been back for the same fix. I think it may be a dealer mechanics "fix" rather than an official technical note "fix" from Solihull. So if you have had this problem too give your dealer a visit and ask them about it. |
Tue Jun 28 2005 6:37pm |
Tim, I quized my dealer today over the bonnet catch issues & unfortunately he or the dealership hav'nt come accross any such failings as yet, but looking at the quantity they are shifting I'm sure it will only be a matter of time because it seems as though it is a common problem.I have made him aware of other peoples experiences re this & other points raised on this site.
Wed Jun 29 2005 10:41pm |
gribnau Member Since: 17 Jun 2005 Location: Santa Clara, Bay Area, CA Posts: 86 |
My service manager said to let the bonnet fall in place from approx 15" height and put some force behind it - he mentioned that for YEARS landrover bonnet's need to be closed with force but not push it down but let it fall in place with force - i hope this makes sense.... - Robert
Wed Jun 29 2005 10:54pm |
BulletProofBomb Member Since: 12 Jan 2010 Location: Lanarkshire Posts: 164 |
Not trying to resurect an old thread here, but this ones helped me out a storm. Bonnet flapping at over 80MPH, search the forum, go out to car, lift bonnet to about 10 inches, cross fingers, close eyes, pray to Thor and SLAM.
Wed Feb 03 2010 5:16am |
Thanks Bullet, much appreciated
Wed Feb 03 2010 8:16am |
