![]() | Home > Maintenance & Modifications > Mounting a second battery under the bonnet |
MikeS Member Since: 24 Dec 2009 Location: Parkdale, Melbourne Posts: 261 ![]() ![]() ![]() |
Ready made kit from Oz, pretty much plug 'n play. They do an additional kit fully wired to run an additional socket in the boot as well.
lespes Member Since: 16 Jun 2008 Location: Channel Islands Posts: 1052 ![]() ![]() ![]() |
Very good kit, easy to install, all bits included with very straightforward instructions |
Streaky Member Since: 31 May 2010 Location: Dubai Posts: 259 ![]() ![]() ![]() |
I've not got around to doing this yet but am making plans to do the work soon.
Just remove rear plastic cover on opposite side to main battery location, looks identical but opposite side and still at rear of compartment |
raadar Member Since: 07 Oct 2010 Location: sunshinecoastQ Posts: 38 ![]() ![]() |
streaky,
Some useful info there...thx.
from my knowledge of what is available, a yellow top should fit into the space however, at 55 AH it will not run your fridge etc for very long. my10D4se3Ltdv6 current
Yellow or blue top fits, it is a deep re cycle battery, never had problems with running mine flat even with heavy usage |
shepp Member Since: 15 Nov 2010 Location: Bingley Posts: 440 ![]() ![]() ![]() |
found this if it helps with installation and location of secondary battery
