Home > Technical > Temperature needle keeps dropping |
marksgd Member Since: 10 Oct 2010 Location: Worcestershire Posts: 68 |
Hi . I have just bought a 06 plate RRs hse The temperature needle keeps dropping to cold also the warning "Low Coolant" keeps pooping up. The engine sometimes revs to 1.5 revs then goes back to 1.0 then up & down then setles down seems to happen when the temperature needle drops down to cold. The coolant level was full to the top , so i have drained out 3-4 cups of fluid. When i start the engine the coolant goes into the coolant box from the top pipe from the rad is this normal????? Please advise as i dont want to run it & knacker it.. |
Sun Oct 10 2010 12:40pm |
Streaky Member Since: 31 May 2010 Location: Dubai Posts: 259 |
Possible air lock in the system?? |
Mon Oct 11 2010 4:50am |
I took it into alltrack 4x4 today , he hooked it up to the diagnostic it came back faulty left hand EGR valve & oil temperature senser . Hopefully that will cure it fingers x |
Mon Oct 11 2010 4:08pm |
Needle kept dropping cos Oil temperature senser was knakerd had it replaced & egr valve . The Rangey drives great |
Thu Oct 28 2010 7:10pm |
Vadim Member Since: 20 Apr 2010 Location: London Posts: 855 |
great news, congrats! Vadim A. |
Thu Nov 04 2010 6:52pm |
Cheers |
Thu Nov 04 2010 8:31pm |
