Home > Technical > Upper tailgate release
Page 2 of 4 <1234>
sweetafton
England 2011 Range Rover Sport Supercharged Santorini Black
Anyone??????? Shocked
Post #267330 Fri May 28 2010 2:27pm
m14rsh
England 2005 Range Rover Sport Supercharged Buckingham Blue
Have simile issue, would like to hear your outcomes...
Thanks 2005 (55) RRS 4.2 V8 S/C Buckingham Blue
All bulbs changed for LED's
Graphite Powder Coated 20" RRS S/C Alloys
Side Steps
Tints
http://rrsport.co.uk/forum/topic1760-45.html
Post #276726 Sun Sep 26 2010 11:24pm
m14rsh
Ordered a new switch from the bay to see if it works before trying the new tailglass option...
Here is what I found when removing the switch;
The inside of the switch was very wet, plastic all discoloured and in poor condition.
The metal contactors within were completely corroded.
Everything else within the tailgate was bone dry and not corroded, removed the number plate bulb housing and still no water, just in the switch!
Side Steps
Tints
Post #277061 Thu Sep 30 2010 8:30pm
sweetafton
Wonder how you would seel it from water getting in. Mine was changed by dealer. Will check mine again now that i have seen yours m14rsh. Big Cry
Post #277091 Fri Oct 01 2010 7:43am
RRSSTEVE
United Kingdom 2006 Range Rover Sport TDV6 HSE Zermatt Silver
HI IT MAY BE JUST THE MICRO SWITCH INTHE HANDLE . A FREELANDER USES A SIMILAR IF NOT IDENTICAL HANDLE. 15 MINUTE JOB.
Post #277122 Fri Oct 01 2010 6:43pm
Tim in Scotland
Mine was actually fixed while I was away - my father was driving the car to give it it's monthly exercise run and had a turbo sensor failure so the car was taken into the local dealer who were replacing the tailgate and did the 2 jobs at once. The new tailgate came into the dealers on the 4th March, the day I went to sea again and they held it until either I or the car came in, so from ordering to receipt was about a month but it does seem to be a bit taking a sledge-hammer to crack a nut doing it that way when you see how easy it is to repair yourself if you have the know-how. The problem is after you have repaired it how do you get the whole thing watertight so it does happen again. Would be interesting to know it it only happens to cars kept outside rather than garaged as to me the water that came out was condesation rather than road water thrown up while driving, it was too clean and "fresh" (it's OK I'm used to doing the "is it fresh water or not" test from the ships where it is important to know if any unaccounted for water in the ship is sea water or freshwater and tasting it is the easiest, if not the most sensible way of finding out as it could of course not be water at all!!) 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #277124 Fri Oct 01 2010 7:06pm
m14rsh
Was thinking about some clear silicon sealant between the rubber surround and the switch plastic backing. As it seems that's the only wet area. May try it with the old switch and see if water gets in it whilst i await delivery of the new switch mine lives outside and it's raining all weekend i reckon. 2005 (55) RRS 4.2 V8 S/C Buckingham Blue
Side Steps
Tints
Post #277125 Fri Oct 01 2010 7:18pm
m14rsh
Got the new tailglass switch today and replaced the old one. It seems that LR realised their problem with this switch as the new switch had a tar like substance fixing and sealing the rubber switch surround to the plastic switch housing. Still no damp within the tailgate but there was plenty of damp again within the switch which i had dried out and replaced last week. All working and one happy owner again. No tailglass replacement required.
Over and out. 2005 (55) RRS 4.2 V8 S/C Buckingham Blue
Side Steps
Tints
Post #277502 Thu Oct 07 2010 7:28pm
Rislar
m14rsh have you got a link to the item on the bay? If it aint broke leave it!
MY 18, Autobiography
MY 05, 07, 10,
Post #277619 Sat Oct 09 2010 7:08pm
m14rsh
Type this into ebay search bar and you will find it.
RANGE ROVER SPORT TAILGATE RELEASE SWITCH (UPPER) TD V8
Hope it helps
M 2005 (55) RRS 4.2 V8 S/C Buckingham Blue
Side Steps
Tints
Post #277620 Sat Oct 09 2010 8:04pm
Rislar
Awesome thanks bud i managed to get one, top job Thumbs Up If it aint broke leave it!
MY 05, 07, 10,
Post #277621 Sat Oct 09 2010 8:21pm
m14rsh
Pleased to help. Had you already removed your current switch and made sure it was only this that was the problem and not a lot of water penetration in the entire lid? I did this and luckily found it was only the switch but as you can see, others had bigger issues other than just the switch. Hope it fixes it for ya. I know it is quite a simple swap over but I have made a video of me swapping mine over and shall try and upload it later/tomorrow for others.
Side Steps
Tints
Post #277622 Sat Oct 09 2010 8:28pm
Rislar
Hi again, what i did was programmed the key fob 3 button to check that it opens and seeing as it did that would mean the switch itself has perished, well thats my reasoning lol If it aint broke leave it!
MY 05, 07, 10,
Post #277623 Sat Oct 09 2010 8:36pm
m14rsh
Ok, makes sense, how did ya program the key fob if the button didn't work though? I tried that...
I also knew the lock worked because of the beauty of the LR electronics, their popped everytime I put the key into the ignition! Was annoying so much that we ended up being in stitches because it would happen all the time and then never for ages. 2005 (55) RRS 4.2 V8 S/C Buckingham Blue
Side Steps
Tints
Post #277627 Sat Oct 09 2010 8:46pm
Rislar
If I'm honest i think it was already programmed for the switch as you know you need to hold the button in and the switch together to program it, so that would mean the contacts would be working then the switch would be, i just never thought of it before i tried until you mentioned it Embarassed Whistle If it aint broke leave it!
MY 05, 07, 10,
Post #277629 Sat Oct 09 2010 9:15pm
Page 2 of 4 <1234>
