![]() | Home > General > Problem - Any ideas please? |
Texstar Member Since: 27 Aug 2006 Location: W.London Posts: 208 ![]() ![]() |
I have had the 'won't change up' problem with the gearbox |
KiwiRRS Member Since: 22 Aug 2007 Location: Wellington Posts: 92 ![]() ![]() |
I had the same when the fuel pump and/or filter were bad. Changed them and had not problems since. |
GIB 984 Member Since: 31 Jul 2007 Location: Midlands Posts: 77 ![]() ![]() ![]() |
Spot on Texstar! Diagnostics revealed two problems - faulty brake light causing the nightmare with the transmission and suspension - Unbelievable ![]() First one sorted in 2 seconds with a new bulb ![]() Will let you know if it works! Best Wishes Gary |
