Home > Technical > Steering Off Centre
leedsunited
United Kingdom 2008 Range Rover Sport TDV6 HSE Java Black
Steering Off Centre
Had 2 new front tyres fitted yesterday and have now noticed that when driving to remain in a straight driving position the steering wheel is slightly of centre to the left, anybody have any suggestions to the cause.
Thanks
Post #273855 Sat Aug 14 2010 2:38pm
Bobby
Alignment? Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #273873 Sat Aug 14 2010 9:30pm
JonnyDangerous
I have this exact same problem on my MY10. Still on original tyres. Car going into LR next friday to be checked.
Post #273881 Sun Aug 15 2010 7:26am
leedsunited
But how can the alignment be out just by changing the tyres Question
Post #273938 Mon Aug 16 2010 8:25am
leedsunited
Alignment checked and fine, incorrect pressures would appear to have been the cause
Post #274002 Mon Aug 16 2010 4:09pm
Jimmy_75000
just to follow up on that...
On my 2010, steering seems slight off to the left.... tough it was due to the nature of the road but after a 2,000 miles round trip in France last week, it is always the case, despite driving on "both side" of the road... even more obvious on highway driving in France... if road turn to the right (slow highway turn...ie one u take at 90 mph), steering with be spot on the middle.... road going left, steering a good 1/4 to the left...
I have check the pressure several times and two realignment since easter but to no effect... one more thing for the dealer? Range Rover Vogue ‘17 TDV6
Gone: Range Rover Vogue '11 4.4TDV8, Range Rover Sport ‘59, Range Rover Sport ‘56
Post #275059 Tue Aug 31 2010 7:45am
ilard
Isn't it the case that they need to centre the steering wheel and then correct the alignment? Idea
Post #275064 Tue Aug 31 2010 9:29am
2nd Rower
Australia 2008 Range Rover Sport TDV6 HSE Chawton White
I had this issue for many months between about Mar 09 and Sept/Oct 09... The dealer and even land Rover kept claiming it was road camber. They eventually fixed it, but when they did they claimed there was no issue found! So I therefore have no idea what they did to correct the issue.
Post #275065 Tue Aug 31 2010 9:52am
Jimmy_75000
I would hope that the tech know what he was doing but will double check that!!!
You're right....I now remember your posts abt it... shame they didn't told you what they've fixed Range Rover Vogue ‘17 TDV6
Post #275066 Tue Aug 31 2010 10:25am
MJW267
had full wheel alignment done and steering wheel has been off centre ever since - not by much but trye pressures make no difference.
Post #276327 Mon Sep 20 2010 9:32am
Bobby
After completing the four-wheel alignment, if the steering wheel is more than three degrees from the straight ahead position, remove the steering wheel and reposition on the nearest spline to the straight ahead position. Malaysia Boleh!
Post #276338 Mon Sep 20 2010 11:46am
RichardM
2010 Range Rover Sport TDV8 HSE Galway Green
Noticed this on mine too today. Will check the pressures asap in case it is that. Strange I hadn't noticed it but before now I keep looking at it! WINNER - 2009 ‘Just Doing What It’s Designed To Do’ Award
2010 TDV8 HSE Galway Green - Adaptive Cruise - Sunroof - Privacy Glass - 5 Spoke Alloys
2009 TDV6 3.0 HSE Buckingham Blue - GONE
Post #276939 Wed Sep 29 2010 9:20pm
