Home > Technical > Front Suspension Knock Improvement - New TSB
bermyandy
2013 Range Rover Sport Supercharged Zermatt Silver
anyone know the cost?
Post #243236 Fri Nov 20 2009 3:16pm
Micrometer
United Kingdom 2010 Range Rover Sport Supercharged Java Black
Thought i'd post my experience here on this as i now know it works after a few miles.
Low expectations turned out to be unfounded! This was almost straight forward Very Happy
So i had the masses fitted to my vehicle and popped around the block to try it - massive improvement but still there slightly so i gave them the keys back and asked them if they could try and get rid of it completely - although to be honest i was already happy - pushing my luck may be but 4 sets of DR bushes and a DR actuator had gone into land fill up till now so i was keen!
They had the car for another day and fixed it:
I was armed with alot of info from here to ask questions:
I asked was it bushes (again) - they said they had checked them and no, not bushes, new DR bushes make it better temporarily not permanently, they do not knock they "transmit knock" into the car. WHAT A SUPRISE - SURELY THE FACT THAT THEY'VE CHANGED DR BUSHES 4 TIMES BEFORE WOULD SAY THAT ITS NOT BUSHES THATS CAUSING THE PROBLEM!!!
I asked was it the small body dampers - they said they had removed them but the dampers dont knock they "transmit knock" into the car.
I asked was it the DR system - they said no, the DR system was fine it doesnt generate this bumpy road knocking noise only the one where you turn the wheel left to right quickly will be heard. (although to be fair that has improved now as well). - SO WHY HAVE I HAD A NEW ACTUATOR - OH I KNOW.. IT COMES WITH NEW BUSHES WHICH MAKES IT GOOD TEMPORARILY. - DOH
I asked was it ball joints - they said they had changed the ball joints as my car had the smaller diameter old versions and they were suspect. - HOW THEY MISSED THIS THE LAST 4 TIMES I DONT KNOW!
They had checked lots of other stuff as well, but basically just put on new ball joints and the masses and removed the small body dampers. Voila!!!! Gone Very Happy 3500 MILES AND STILL NO NOISES.
He did say their understanding of this issue had got better as more info has come out of LR.
So i've come up with an instruction manual for the LR dealers so they can get up to the level of mine.
1) DO Take off small front body dampers by the chassis mount.
2) DO Fit mass dampers to chassis frame.
3) DO Change lower front ball joints
4) DO check nut torques and control arm bushes, drop links etc in LTB00204v4.
5) DO NOT change DR bushes unless you want customers to come back in 2 months with the same problem.
6) DO NOT change countless other components and fit the new ones incorrectly causing a magnitude of other issues that are completely un-related.
7) DO NOT use the last version of the bulletin or some other one thats close in number, or try to remember whats in it. USE THE RIGHT ONE AND READ IT. Thumbs Up
DO ALL THIS AND YOU WILL MAKE US ALL AS HAPPY AS ME!!! Trust me, i'm an Engineer!
Post #244042 Mon Nov 30 2009 3:42pm
2nd Rower
Australia 2008 Range Rover Sport TDV6 HSE Chawton White
Does anyone have these referenced TSB's:
LTB00123v4
and
LTB00198
Post #275137 Wed Sep 01 2010 8:21am
airwolf222helicopters
had mine done for around £80 mark from dealer when i had new version of ball joints done but still have a knock
ride has improved with dampers tho bloddy heavy the bits in kit ?
bobby is it ok to pm u? when is best time ?
got couple of questions for you
Post #275177 Wed Sep 01 2010 7:08pm
Bobby
LTB00198 Smile
LTB00123v4 concerns vehicles WITHOUT Dynamic Response... I presume yours is WITH? Confused
airwolf, anytime is OK to PM me.. Wink Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #275330 Sat Sep 04 2010 2:28am
2nd Rower
Bobby wrote:
LTB00198 Smile
Bow down many thanks Bobby.. my vehicle is a standard 2.7TD without dynamic response, so if you have LTB00123v4 that would be appreciated.
Post #275339 Sat Sep 04 2010 7:17am
Bobby
OK 2nd, here's LTB00123v4 Wink Malaysia Boleh!
Post #275357 Sat Sep 04 2010 11:38am
2nd Rower
Many thanks again Bobby.... Strange request I know, but do you happen to have v1. v2 and v3 of this TSB?
Thanks
2R
Post #275399 Sun Sep 05 2010 11:07am
Bobby
Sorry mate, that's the only version I have. Sad Malaysia Boleh!
Post #275401 Sun Sep 05 2010 11:33am
