Home > Technical > Will 19" HSE alloys fit on a Defender?
BIG DJ
As title really!
Anyone know the answer? Thumbs Up
Post #275156 Wed Sep 01 2010 1:21pm
AlexMckie
United Kingdom 2005 Range Rover Sport TDV6 HSE Rimini Red
Not without adapters.... I'm afraid....
Post #275158 Wed Sep 01 2010 2:07pm
Streaky
United Arab Emirates 2008 Range Rover Sport Supercharged Alaska White
Me thinks a bit more body work might be needed as well. Adaptors will only correct the stud pattern etc.....but rims that are 3 inches bigger might cause all sorts of rubbing problems as well.
Whats the off-set of the rims that you want to fit? I think the turning circle will also be as big as a football pitch!
Post #275159 Wed Sep 01 2010 2:21pm
Bodsy
Site Sponsor
Yes they will fit as long as you have the D3/RRS adapters (about £400 for a set of four).
Clearance on bodywork is OK too but may rub on extremes when heavily loaded off road Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #275160 Wed Sep 01 2010 3:04pm
BIG DJ
Thanks guys Thumbs Up
Post #275162 Wed Sep 01 2010 4:39pm
Tim in Scotland
Post a pic when you have fitted them DJ! I've just fitted a set of Anthracite ZU's to my 90
and a set of 20" Stormers have just arrived for the FFRR
 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #275167 Wed Sep 01 2010 6:06pm
DMike
United Kingdom 2006 Range Rover Sport TDV6 HSE Bonatti Grey
20" wheels will fit a Defender..... Just! Whistle
Has been converted to air suspension, and that was as low as it would go, sitting on the bump stops :lol:
Post #275169 Wed Sep 01 2010 6:23pm
BIG DJ
The stormers look lovely Tim Thumbs Up
I don't have a Defender. Just changed my 19's to 20's and a guy at work was looking at buying them for a defender he's rebuilding.
Post #275173 Wed Sep 01 2010 6:55pm
BIG DJ
Is the EPB Censored ed already on the FF. Had to put a brick under the wheel? Laughing
Post #275174 Wed Sep 01 2010 6:57pm
Tim in Scotland
If you look closely at the wheel there are also no wheelnuts holding it onto the car it was just placed against the 19" wheel that was on the car.............................. the single wheel braking device was necessary to stop the wheel rolling away during photography! If you take a look at this thread over on FullFatRR you can see the fun I had with all the wheel designs that are in my garage and seeing which look good with the FullFat..........................
http://www.fullfatrr.com/forum/topic2892.html 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #275179 Wed Sep 01 2010 7:14pm
BIG DJ
Laughing I didn't notice that. Just a few in the garage Tim!
Post #275181 Wed Sep 01 2010 7:56pm
codfather
Scotland 2010 Range Rover Sport 3.0 TDV6 SE Santorini Black
tim
they look huge on the car, is it just a combination of access hight an perspective? great wheels Thumbs Up ,best design ever imho!
btw where is your ship just now, i use shipAIS to keep track of boats passing by the window!
cheers
dave MY10 TDV6 SE (debadged Wink ), Santorini Black, Flappy paddles, Privacy Glass, 20" Stormers, Mudflaps!
Gone: a comprehensive list of imprezas and a Merc ML AMG
Post #275185 Wed Sep 01 2010 10:22pm
Tim in Scotland
Codfather - I'm between ships at the moment, on my holidays, however the last ship Maersk Sydney arrives in Balboa Panama tomorrow noon'ish. The two "next ships" that have been mentioned for November appointment are Maersk Sarnia which is in mid-Pacific, west bound to Yokohama/Tokyo (ETA Yokohamam 8th September) at the moment and the other one is Maersk Miami, currently at Mina Sulman (the port for Bahrain). Take the AIS that you see over the internet with a pinch of salt - for security reasons real time AIS is not generally broadcast on public access websites. If you have an iPhone then one of the better shiptracker apps is Shipfinder which is real time.
BTW I don't work on any boats, they are all ships................................... I sail on a boat for pleasure though, just remember ships carry boats (lifeboats and tenders on passenger ships), boats cannot carry a ship..........
Re the wheels - yes the FullFat was parked at access mode - I always lower my cars when I park them - it helps avoid battery drain problems 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #275198 Thu Sep 02 2010 8:24am
codfather
tim, thanks for the tip on the battery, i had no idea that could happen, i tend to keep mine in normal hight as i thought it might go wrong if i kept playing with the selector!
the boats i mentioned are fishing boats, who for obvious reasons tend to switch off their beacons so no one knows where they are!
i see it is all maersk ships you are on, we use nofolkline (now DFDS) for our european deliveries
cheers
Post #275210 Thu Sep 02 2010 11:14am
Tim in Scotland
Coastal fishing boats are not legally required to carry AIS which is a more likely reason for them not having one! It was something foisted on us by the Americans after 9/11 and it's a pain in the butt, I switch ours off whenever possible to stop my less competent officers from using it for anti-collision purposes, they get taught everything about it at Marine School, except the shortcomings and dangers of using it for anything other than an information system. It is a brilliant system when used properly, but very dangerous when used for purposes that it was not designed for, in the hands of the inexperienced. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #275213 Thu Sep 02 2010 12:11pm
