Home > Technical > "Check Brake Pads" ??
Adam RRS
I keep getting "Check Brake Pads" appear on the display every time I brake.....
What does this mean?!?!
Rolling with laughter Rolling with laughter Rolling with laughter
Only joking - Just wondering the best/cheapest place to buy Brembo pads from and what brand are the originals? So I dont buy pattern parts WINNER - 2009 Best in Class Range Rover Sport Award
MY14 Corris Grey RRS HSE SDV6
Post #274853 Fri Aug 27 2010 4:51pm
scott7
Scotland
Brembo don't make brake pads, if you go to lr you'll get pads in a lr box, made by some of the big manufacturers and branded land rover, I bought a set of ebc pads from e bay, much cheaper than lr and as good as originals if not better.
Post #274873 Fri Aug 27 2010 6:55pm
scott7
Scotland
Post #274874 Fri Aug 27 2010 7:00pm
Bob
2006 Range Rover Sport Supercharged Zermatt Silver
I bought a set of front pads (Mintex, I think) off ebay for around £80 for the Brembo calipers.
Don't forget, if you're changing them yourself, you almost never get the wear sensor with the pads, so you'll have to buy it separately (c.£12), because you'll never get the old one out without breaking it. When putting a new wear sensor in, you can either;
1. Remove the wheel arch liner, and connect the sensor lead to the proper plug (that's what I did), or;
2. Chop the cable, and re-solder the new sensor onto the old lead.
Hope this helps.
Bob.
Post #274952 Sun Aug 29 2010 9:07am
Adam RRS
i'm taking it to my local garage.... sounds expensive already! Booked in for tomorrow.... cant wait to stop that constant beeping every time i break Twisted Evil WINNER - 2009 Best in Class Range Rover Sport Award
Post #275101 Tue Aug 31 2010 6:54pm
mlines
I bought Mintex pads from www.brakesint.co.uk. Came to £50 including the sensor wire. 2016 RRS 4.4 TDV8 Autobiography Dynamic in Montalcino Red and Stealth Kit
Post #275782 Sat Sep 11 2010 1:32pm
