Home > Maintenance & Modifications > Rear LED Lights on 2006 RRS
globe195
United Kingdom 2006 Range Rover Sport TDV6 HSE Bonatti Grey
I am looking to fit some "Rear LED lights" on a 2006 RRS and they are straightforward but they also need resisters fitted and I am not sure where these get wired into as there are about six different coloured wires on the loom that comes from the body? Does anyone happen to know where I can find some step by step instructions (photos would be good) of where the live feed and earth feed go to on the loom? What colour is Live and what is earth? Any help would be great?
thanks
Post #274773 Thu Aug 26 2010 7:32pm
td6006
2005 Range Rover Sport TDV6 HSE Zambezi Silver
fitting led rear lights
Hi globe 195 if you search me in members td6006 and look thriugh my post all the info you want is there inc photos.you will need 50w 6ohms resistors find them on ebay about £6 fit them in the boot behind side panels very easy takes about an hour let me know if you need any more help m8
Post #274778 Thu Aug 26 2010 8:13pm
globe195
Thanks TD6006. I did check out your post and the photo shows the resisters fitted to the back of the light unit itself as opposed to the inside the boot side panels as you suggest?
Do you happen to have a photo of where exactly you mean and how you have connected the resisters up and also to what coloured wires?
I already have the resisters and each one has a green wire on one end which I believe is "live" and white wire on the end which I believe is the earth? but it's where they need to be connected too inside the boot side panels that I am unsure about? Any further help would be great?
Post #274790 Thu Aug 26 2010 11:25pm
iz6byo
2006 Range Rover Sport TDV6 HSE Buckingham Blue
i'm waiting them ....
if u wait some days i'll post some pics.
bye Very Happy
Post #274812 Fri Aug 27 2010 8:21am
globe195
Thanks Smile
Post #274841 Fri Aug 27 2010 1:21pm
td6006
rear lights
Hi globe 195 search me out again then on my posts look up RRS PIMP reply to me then click on his gallery and there are the pics on how to fit in rear boot and his reply gives colours to connect to regards td6006
Post #274891 Fri Aug 27 2010 10:02pm
globe195
Thanks TD6006 Thumbs Up
Post #274956 Sun Aug 29 2010 10:07am
Jonathan
England 2012 Range Rover Sport SDV6 Autobiography Fuji White
Hi Globe 195 = where did you get the LED lights from?
Jonathan Jaguar XKR Convertible
MY 2012 Range Rover Sport TDV6 Autobiography in Fujian White....Mmmmmmm
Range Rover Evoque 2.2 Prestige in white - gone
Porsche Boxster S White with lots of extras! Gone
Lotus Elise 2011 Touring for sunny days - gone!
Previously....
RRS TDV8 Black 57 Plate
645ci
Jag XKR Convertible (my wife still loves this car!)
BMW 530i
BMW 328i (I loved this car)
Golf R32
Post #274999 Mon Aug 30 2010 8:17am
globe195
Purchased them on ebay (£340). Recieved 2 right ones at first but managed to get that sorted out and recieved a left one two days later? Thanks to some help from some of the forum posts I managed to get the resisters fitted and they are now up and running and working Ok! The only problem I now have is that the following dayI noticed that the right cluster was badly misted up and this did not look good at all? I contacted the seller and explained the situation but he said he is not sure if he can take it back as I have modified it by fitting the resister to it?(I chose to fit it directly to the unit by first putting some heat resistent metal tape on the unit and then some heat resistent bonding glue on top of that before sticking the resistor on) I am waiting to hear back from the seller to see if his supplier will take it back but as far as I am concerned it was not fit for purpose before I made any modifications? Watch this space??
Post #275309 Fri Sep 03 2010 4:51pm
Vadim
United Kingdom 2010 Range Rover Sport Supercharged Santorini Black
Hopefully you will be able to sort this all out? And by the way? Why so many question marks?? Vadim A.
Post #275312 Fri Sep 03 2010 5:39pm
BIG DJ
Remove the light and put it in airing cupboard or somewhere similar to dry it out properly. Then get some sealent and run it round the seals. Just sounds like it has gone slightly and getting damp inside.
Post #275313 Fri Sep 03 2010 5:56pm
globe195
Thanks Big DJ. What type of sealant would you recommend?
Post #275319 Fri Sep 03 2010 7:02pm
BIG DJ
I would say any silicone sealent. The other thing that you could try is to heat the seal up on the light with a heat gun or a hair dryer may do it. This may reseal it as it cools down?
Post #275352 Sat Sep 04 2010 11:11am
