Home > Technical > Gearbox problems???
BIG DJ
Gearbox problems???
I have a couple of issues that I'm not sure whether are normal or not. Firstly at times when I slow down then reapply the throttle there's a bit of a joult as if it's dropped down to the correct gear but doesn't select smoothly.
Secondly again at times when pulling away from a stand still it doesn't change up to second smoothly. If I pull off gently on the throttle it's fine, full on the throttle is fine but about half throttle it happens.
Any of you knowledgable guys got any ideas. It's under warranty but don't want to waist time putting it in if it's just part of owning a RRS also as it doesn't seem to happen all the time.
Thanks
Adam Thumbs Up
Post #274330 Fri Aug 20 2010 7:19pm
RichardM
2010 Range Rover Sport TDV8 HSE Galway Green
Adam, for the second part on half throttle what happens exactly?
The first part sounds ok if it's just the gearbox dropping down to first which will jolt the car if your still moving.
Hope you and the family are all well mate. WINNER - 2009 ‘Just Doing What It’s Designed To Do’ Award
2010 TDV8 HSE Galway Green - Adaptive Cruise - Sunroof - Privacy Glass - 5 Spoke Alloys
2009 TDV6 3.0 HSE Buckingham Blue - GONE
Post #274332 Fri Aug 20 2010 7:40pm
BIG DJ
Hi Richard, Yeah all fine thanks. You?
I'll pull away with the throttle applied about half and when the car changes from 1st to 2nd it's a little joulty just like the other issue. The rest of the gear changes are fine just 1st to 2nd.
The other issue shouldn't be selecting 1st as I'm more at a speed for 2nd?
Post #274333 Fri Aug 20 2010 7:45pm
RichardM
Yeah good thanks mate, especially as it's Friday night and the bottle of wine has been opened!
I misunderstood sorry, I thought you meant it was when it kicked down into first from second which can be harsh. WINNER - 2009 ‘Just Doing What It’s Designed To Do’ Award
Post #274335 Fri Aug 20 2010 8:27pm
