![]() | Home > General > what does 89% worn REALLY mean |
Welcome to the site. The solution is simple with the RRS - wait until the warning comes on that the break pads are shot and get an independent to replace. 2005 Zambezi TDV6 - Gone but not forgotten
Endjin Member Since: 22 Jun 2007 Location: Aberdeenshire Posts: 2087 ![]() ![]() |
Name & Shame them!
JC1 Member Since: 24 Oct 2009 Location: Berkshire Posts: 939 ![]() ![]() ![]() |
NeilR Member Since: 21 Jun 2005 Location: wakefield/West Yorkshire Posts: 246 ![]() ![]() ![]() |
Name them,,, its disgusting..... its day light robbery bordering theft...
Vadim Member Since: 20 Apr 2010 Location: London Posts: 855 ![]() ![]() ![]() |
That is very interesting VA. I might just do that actually. but I read somewhere that there are only 2 sensors installed. One in front (left or right wheel), and another rear one. So if one without the sensor gets used out you never find out about it... True or flase? Regards, Vadim A. |
The pads should wear evenly though, although more load o the front brakes, but if there is a sensor front and rear it shouldnt be a problem unless you have a sticking brake or something but thats another problem and hopefully you would know it before the pad was shot. |
TBH I don't know. 2005 Zambezi TDV6 - Gone but not forgotten 2009 Alaska TDV8 - Gone and much missed. ![]() WINNER - 2009 �Idler Of The Year� Award Runner Up - 2009 �Just Doing What It�s Designed To Do� Award DO NOT CLICK HERE! |
How do you brake only one front/rear wheel? ![]() 4.2SC Chawton White, Stormers Tasmod's Sills, Wind Deflectors, LR Sills Clear Side Repeaters, Towbar Larini Sports Exhaust, K&N Air Filter ______________________________ WINNER - 2008 'Tech-Head Of The Year' Award WINNER - 2009 Outstanding Contribution WINNER - 2009 'Tech-Head Of The Year' Award |
disco4x4au Member Since: 17 Nov 2009 Location: Perth Posts: 147 ![]() ![]() ![]() |
If you're regularly off-road, you can get uneven wear via the traction control operation. particularly if you drive the same route all the time. Not likely though .......... 2015 RRS SDV6 SE, Santorini Black, GOE 2-way HS rods, Traxide dual battery, 275/55R20 Nitto TerraGraplers 2015 Discovery 4 SDV6 HSE - GOE 3-way HS rods, GOE underbody plates and sliders, 275/65R18 Courgia MT |
npinks Site Moderator Member Since: 26 Nov 2007 Location: Watching Posts: 6716 ![]() ![]() |
Is there a mark on the side of the new one to give visual indication on when to swap
lespes Member Since: 16 Jun 2008 Location: Channel Islands Posts: 1052 ![]() ![]() ![]() |
Only one sensor on each wheel, have been reports of un-even wear, which has caught people out, but not that often.
Sensors in front left and right rear pads.
NickM Member Since: 14 Feb 2008 Location: London Posts: 2995 ![]() ![]() |
I have had 3 sets of pads all round and on 2 occasions they have marked the discs quite badly - even at Wokkas day out my pads were screeching like nuts and has a sensor ever shown up on my display? NEVER!! How's that then? |
paulL Member Since: 20 Dec 2005 Location: Barcelona Posts: 263 ![]() ![]() ![]() |
I had an MOT in March where I was told the front brake pads needed replacing, which they did. The car was booked in the next week for a yr3 service where I was told the front brake pads were 30% worn! I had only done about 100mls since replacement!
