Home > Technical > 12v socket on rear of centre console help please
merlin1
2010 Range Rover Sport 3.0 TDV6 HSE Santorini Black
can anybody help in the easyest way to get to the wire that goes to the 12v socket of the rear of the centre consul, so i can hard wire dvd power too,or if there is another 12v power feed near by cheers .
Post #273811 Fri Aug 13 2010 10:19pm
BIG DJ
I think you have to remove the centre console lid and then the storage box underneath.
Post #273820 Sat Aug 14 2010 6:33am
Pull the 12v socket out. 2005 Zambezi TDV6 - Gone but not forgotten
Post #273836 Sat Aug 14 2010 8:24am
BIG DJ
Now that makes more sense. Thumbs Up
I always make things difficult for myself Laughing
Post #273845 Sat Aug 14 2010 11:21am
lespes
Guernsey 2006 Range Rover Sport TDV6 HSE Buckingham Blue
12v socket will not be live all the time though, will need key in ignition, or there is a way to make it pernament live, should be a sticky on it somewhere.
Mine has been wired up to different location but do not know where (not much help is it!) which is a live feed, which does not need key in ignition or keep the systems awake so avoiding serious battery drain. One movie with key in or systems awake in stationary mode will see you needing a jump start
Post #273864 Sat Aug 14 2010 4:53pm
merlin1
so does the 12v socket just pull out or the panel around it cheers.
Post #273895 Sun Aug 15 2010 10:47am
With a little help it should do. 2005 Zambezi TDV6 - Gone but not forgotten
Post #273903 Sun Aug 15 2010 12:42pm
