Home > Technical > Front Parking Sensors
Craig
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Buckingham Blue
Having just acquired my RRS (MY2010) it appears the front park sensor does not work. Parking close to a wall produces no warning at all but when you put the stick in reverse the beeping starts. Without movong, if you put the stick in drive (with the brakes on!!) it still makes no sound. The rear parking sensors work fine.
What am I doing wrong? Confused
Post #273357 Sun Aug 08 2010 10:36am
RichardM
2010 Range Rover Sport TDV8 HSE Galway Green
They aren't activated until the car is put in reverse unless you press the button on the dashboard. Then which ever way they were activated they will work until you go above 10mph or so. WINNER - 2009 ‘Just Doing What It’s Designed To Do’ Award
2010 TDV8 HSE Galway Green - Adaptive Cruise - Sunroof - Privacy Glass - 5 Spoke Alloys
2009 TDV6 3.0 HSE Buckingham Blue - GONE
Post #273359 Sun Aug 08 2010 12:46pm
Craig
Thanks...I've now found the elusive button. All working well!
Post #273361 Sun Aug 08 2010 1:49pm
