![]() | Home > Technical > Handbrake/Parking Brake Locking on & screeching |
This used to be a very common problem but is les reported since there was an upgrade carried out. You need to take the car into a dealer service bay - either you have a loose pad causing the system to bind on or they need to clean and lubricate the system. Have you recently been offroading in mud as this is a frequent cause of the problem.
enzojunior Member Since: 25 Jun 2008 Location: Sydney Posts: 26 ![]() ![]() ![]() |
Thx Tim. No off-roading or mud. What the hell is the screeching all about? I can understand the binding, although if they're binding, how does the reboot release it? 2006 Black/Alpaca, Hi Ice, Dynamic Pack, 19" wheels, Clear Pack... |
A couple of TSB's in my Gallery. |
PJPR01 Member Since: 12 Mar 2006 Location: Houston, Texas Posts: 355 ![]() ![]() ![]() |
Does it sound like someone is killing a cat?
anthony-apl Member Since: 07 Oct 2007 Location: sunny stockport Posts: 259 ![]() ![]() ![]() |
just had mine done under warranty
dcc Member Since: 23 Jun 2008 Location: Channel Islands Posts: 32 ![]() ![]() ![]() |
I have just had a similar experience. In my case I had stopped at traffic lights with the parking brake on. When the lights turned green and I tried to move off there was an awful screeching noise worse than a screaming banshee ( I am sure you could hear it a mile away) and the car would not move. The rear wheels seemed locked.
The EPB release is described in the manual........................................... 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Endjin Member Since: 22 Jun 2007 Location: Aberdeenshire Posts: 2087 ![]() ![]() |
I have a simple solution. I never use the EPB! 2013 Discovery HSE Luxury - 3.0 SDV6 - Santorini Black
BulletProofBomb Member Since: 12 Jan 2010 Location: Lanarkshire Posts: 164 ![]() ![]() ![]() |
It sounds like someone killing a cat in the boot was exactly how I described it to the dealer aswell. What the rest have said new EPB unit fitted. (warranty, phew) |
Fat B'stard Member Since: 12 Jun 2010 Location: High Wycombe Posts: 7 ![]() ![]() ![]() |
Just suffered from the same problem! I bought Marlow High St to a stand still it is that loud. Got home at 1am yesterday and forgot to press the EPB button down when I parked. Neighbours now love me! Dropped it into Graham Goodyer this morning. All fixed! |
pcregeen Member Since: 06 May 2010 Location: Huddersfield Posts: 100 ![]() |
happened no less than 4 times in a year on my disco 3. Common fault. note to all, rarely covered in aftermarket or approved used warranty |
