Home > Maintenance & Modifications > SQ and audio upgrade again...
kluklut
United Kingdom 2007 Range Rover Sport TDV6 HSE Adriatic Blue
Okay, before anything, I've searched the forums, with no luck!
I'm doing this incrementally and retaining the stock look as much...I've swapped out the HK speakers for focals, and the sub for a pioneer... and the improvement is substantial, clearer...
Next step is to clean up the SQ a bit, so i'm thinking to add my rockford fosgate 360.2 (its been languishing in the garage for 7 months) and maybe a power amp to give the sound more oomph.
Question is.. guys, are there any power amps compatible with the high-line HK??? and where does the 360 fit? On the inputs before the amp right?? Any comments welcome! Thanks!
Post #262096 Tue Apr 06 2010 2:22am
Harry HST
United Kingdom 2005 Range Rover Sport 4.4 V8 HSE Java Black
are you just looking to put an additional sub and amp in the car by connecting it to the original stereo?
Post #263858 Thu Apr 22 2010 3:38pm
kluklut
No Harry, Ive already done that... I'm looking to increase the power delivered by the HK amp to the speakers. With minimal wiring and disruption, by adding a power amp... Simple but seemingly impossible part to source!
Post #264573 Thu Apr 29 2010 12:13am
hario69
Re: SQ and audio upgrade again...
Hi I want to do the same thing, can you let me know the specs of the speakers. I just want to replace them, not the amps
Thanks paul
Post #271385 Thu Jul 15 2010 10:06pm
