![]() | Home > General > PARKING SENSOR FAULT |
issy-olivia Member Since: 03 Feb 2010 Location: durham Posts: 46 ![]() ![]() ![]() |
Do you think ill need to take of my rear bumper to find the broken wire 2006 RR SPORT TDV6 HSE SILVER 22 STORMERS RUNNING BOARDS FULLY COLOUR CODED WIND DEFLECTORS CHROME MIRRORS WINDOW TINTS |
To change the inner rear sensors, you need to remove the rear bumper cover.
leedsunited Member Since: 04 Aug 2008 Location: Selby Posts: 1368 ![]() ![]() ![]() |
Bobby
Thanx everyone it was finally a broken wire i found on one of the reverse sensors on the rear, still i have a new spare one just incase and no you dont have to have it on the computer to reset it just fix the broken wire and hey prestoe !! Thanx once again folks "" |
merwiz Member Since: 26 May 2009 Location: Wirral Posts: 143 ![]() ![]() ![]() |
I need to change an outer front sensor this weekend, can this be done without removing the bumper??
You will need to remove the bumper cover. Malaysia Boleh!
Streaky Member Since: 31 May 2010 Location: Dubai Posts: 259 ![]() ![]() ![]() |
Since there is a lot of relevent information in this thread I will add to it rather than start a new one.
dazsear Member Since: 23 Nov 2008 Location: Lincolnshire Posts: 851 ![]() ![]() |
Yes Streaky that means the system is not working.
I found out that you can change the front outer sensors without removing the bumper cover IF you've got bendy arms!!
ptwroofing Member Since: 30 Dec 2010 Location: hertfordshire Posts: 38 ![]() ![]() ![]() |
If all sensors are clicking front and rear but still showing fault on dash any ideas what to try next would be much appreciated by someone please |
I had mine plugged into a diag machine, it showed which sensor was faulty.
can someone tell me if my sensors are clicking in reverse and drive could this be a wire or maybe crap on a sensor and is it worth taking bumper covers off or would they not be clicking if it was any of these probs paul |
