![]() | Home > Technical > Computer Code Access |
Bob. Member Since: 03 Feb 2009 Location: SWest Posts: 275 ![]() ![]() |
Hi Vadim
Vadim Member Since: 20 Apr 2010 Location: London Posts: 855 ![]() ![]() ![]() |
Thank you very much Bob. Vadim A. |
The reason I am asking this is that, I got my RRS a week ago, brand new S/C. I think I might have to book it in for a quick check since it seems that sometimes I get a slight delay in gas response too. The way it happens is that when I am going around 30mph, I hit the gas pedal, it speeds up to from 1.5 RMP to 3 RPM and then shoots of like crazy (which is nice). It takes about 2- 3 sec for the whole process. I can clearly feel/see the difference of torque from 2RPM to 3RPM, then it goes like crazy after 3RPM. I was wondering if this is how it is supposed to be. It could be that once I hit the gas pedal is speeds up, realises it needs to change 1 gear down, does that and then shoots off? Because a similar thing happens when on motorway. hit the pedal, it goes 1 gear down, from 6 to 5 and shoots off then.
NightFox Member Since: 02 Mar 2010 Location: North Shropshire Posts: 381 ![]() ![]() |
Are you sure it's not exactly that, kick-down? Have you tried it from a standing start in first, or knocking it down manually as low as it will go before flooring it (the box won't let you change down too low so no worry about damaging the engine)? Alfa Romeo Giulietta 1.8::MG Montego Turbo::MGB GT::Rover Sterling::MGF::MG ZT 190+ Discovery Series II Td5 GS::Discovery 3 TDV6 S::Freelander 2 TD4 XS::Freelander 2 TD4 SE ![]() |
Hi NightFox,
gseum Member Since: 15 Feb 2010 Location: Germany Posts: 32 ![]() ![]() ![]() |
Sure you can without special equipment. ![]() ![]() Greetings gseum |
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 ![]() ![]() ![]() |
This works? Is it a standard PIN?
disco4x4au Member Since: 17 Nov 2009 Location: Perth Posts: 147 ![]() ![]() ![]() |
Yes, it's a std pin, but not sure I trust the DTC readout - only seems to have very limited coverage.
Very interesting video, will try it out tomorrow. Thanks! ![]() |
That 753 hack was well documented for pre 10MY cars by Wiggs on Disco3.co.uk 3 years ago. Unless the Configuration and DTC options have been expanded for 10MY vehicles it only gives fault codes for the screen and nav system. Now if it gives access to all the systems' fault codes that would be interesting! |
