![]() | Home > General > DVD on Sat Nav screen and IPOD control |
NeilR Member Since: 21 Jun 2005 Location: wakefield/West Yorkshire Posts: 246 ![]() ![]() ![]() |
Hi All...look what i have found while browsing today..
M@verik Member Since: 16 Aug 2005 Location: Somerset Posts: 130 ![]() ![]() ![]() |
Thanks for that post Neil - finding a TV solution was one of the 3 main reasons I joined the forum - sad but true. 11 XFR
Thanks Neil! The TV's not for me, but I'll be keeping an eye out for the iPod solution - that's just what I need!
umbertob Member Since: 23 Sep 2005 Location: Pasadena, CA Posts: 944 ![]() ![]() ![]() |
Nav-TV is for real, at least as far as the audio-video interface is concerned. It is an expensive module though, about US$1500 for cars already equipped with RSE, according to a local Nav-TV dealer I contacted, and that is just to get DVD playback on front monitor, which is something you currently cannot do in US-spec cars. Overfinch - which I contacted earlier here in the US - offers a simliar solution for about the same money. The Nav-TV module will allow DVD playback on front monitor whether the car is stationary or not. It will also allow front monitor playback of another A/V source, if supplied (such as a TV tuner, which costs substantially more.) Playback will stop when reverse gear is engaged, that is because there will soon be a backup camera interface also available from Nav-TV that could be added to the system.
grommet Member Since: 28 May 2005 Location: Northern California Posts: 299 ![]() ![]() |
umbertob, if you wire up the factory rear DVD system to the video input that is normally used for overseas vehicles (from the picture, that's what they do too)... is the UI still there that allows viewing? (I've only seen the non-locked out version at shows, which has the UI to show video.)
Wko knows... There has got to be more radical modifications involved than just running a wire from RSE video out to monitor video in. On cars with RSE such as mine, Nav-TV needs this module to be shipped to them to perform the "secret" upgrade. Their local dealer anticipated I would be without radio for a couple of days as my module travels back and forth between them and Nav-TV.
BBlackRRS Member Since: 31 Aug 2005 Location: US Posts: 40 ![]() |
Hello Californians, I live in the county of oranges and spoke to my local NAV-TV rep who the company forwarded me to. He was quoting me $3800 for the job done. I really don't care about the iPod control or DVD input that much although it is a neat feature. I don't have the Rear Ent. System, what i DO want is a backup camera, mainly because I have dark tint and it's a pain in the arse to park at night. For this alone, I am getting quotes around $1800, then I get the runaround from the installer that, "You might as well get the whole shabang and spend the $3800 if your'e going to do that".
There are 3 analog video inputs on the rear of the Touchscreen, one of which is supposed to be fed by the rear DVD video unit. (Note: They are odd connectors.) It's not wired in North America. It's very possible it may "just work" if connected. I have no idea if they changed anything else to prevent it's use. If you are feeling adventuresome, take any portable device with analog composite video out and see if you can get a picture in the "black box" of the DVD controls on the Touchscreen. If that's successful... then you need to figure out how to wire the rear DVD playback unit all the way to the Touchscreen, and the behavior may just be like overseas.
