Home > Technical > Car won't accelerate below 2.500 rpm?!
McBunny
Germany 2006 Range Rover Sport TDV6 HSE Bonatti Grey
my car does not only squeek it also does not want to accelerate at low rpms. And no, it is not due to the weak engine I bought Rolling Eyes Wink it is reaaalllllyyy slow. It takes about 20-40 seconds to get from stop to about 2.500 rpm infirst gear, from then on it accelerates quite normal.
I also have this phenomenon in the other gears but it is especially dangerous in first gear since I can not start the car quickly at a crossing, it more rolls over any crossing which sometimes is quite scary... Confused On the other hand it is nice because my parking sensors don't work at the moment and the car is so slow when parking at least I can not damage my car! Mr. Green
Anyway:
The RRS won't accelerate below 2.500 rpms. Anybody an idea?
It first appeared end of last week when the fuel was almost empty. I thought: Okay, it might be veeery empty, so let us refuel. But the problem is still there. I refueled with V-Power-Diesel so poor fuel quality can not be the reason I guess, also I have de-remapped it a few weeks ago (and drive about 600 mls per week) so a remap can not be the reason, too. The RRS was services about 6,000 mls ago.
Yes, I know, trip to the stealer, but since they do usually do not have any clue I wanted to ask here first to give them a manual where to search! Thumbs Up Wink
Thanks a lot! Cool
And thanks for not shouting RTFM since I do not have time (or the will) to do so... Rolling Eyes Mr. Green RRS TDV6 HSE, 2006, bonatti grey, ebony interior, rear diff, s/c grille and vents, stormers, privacy, tasmods, iphone integration Wink
Post #263445 Mon Apr 19 2010 12:43pm
Endjin
Scotland
Could be your EGR Valves. Had a similar issue with my 2007 2.7 TDV6 and it turned out to be a stuck EGR Valve.
If it is this, then dealer will be able to get the error codes from the car to confirm which one it is. 2013 Discovery HSE Luxury - 3.0 SDV6 - Santorini Black
2013 Evoque 5 Door Pure Tech SD4 - Orkney Grey with Panoramic Roof (Mrs E's new baby)
GONE - RRS - 3.0 TDV6 HSE - Santorini (2010)
GONE - RRS - 2.7 TDV6 HSE - Java Black (2007)
GONE - Porsche Boxster S - 3.2 - Black
Post #263452 Mon Apr 19 2010 2:45pm
lespes
Guernsey 2006 Range Rover Sport TDV6 HSE Buckingham Blue
classic EGR failure symptoms
Lighter pockets for you now!
Post #263492 Mon Apr 19 2010 7:14pm
McBunny
Yeah, problem found and solved, thanks for the help guys! Thumbs Up
lespes was right unfortunately: Lightered my pockets by about 1,400 Euros (incl. repair of two parking sensors and a curtesy car for two days)! Shocked Confused RRS TDV6 HSE, 2006, bonatti grey, ebony interior, rear diff, s/c grille and vents, stormers, privacy, tasmods, iphone integration Wink
Post #266811 Fri May 21 2010 1:21pm
Neutral
Post #266841 Fri May 21 2010 4:08pm
