Home > General > HELP - Door Side Skirting/Trim |
roverGP Member Since: 25 Jan 2010 Location: Boston, MA Posts: 10 |
There's 2 screws on the small skirt on the front fender then on the front door you just pull from the bottom, there's little buttons that unclip when you pull it off. You may need to replace some of them depending if they break. You can pick up extras at your local dealership. then on the rear doors you do the same just pull. |
Tue May 04 2010 2:51am |
KR1005 Member Since: 03 May 2010 Location: Hong Kong Posts: 61 |
That's very helpful many thanks will try. |
Tue May 04 2010 3:13am |
