Home > Maintenance & Modifications > TDV6 EGR Valves (2)
jbd-organ
Ireland 2005 Range Rover Sport TDV6 HSE Bonatti Grey
TDV6 EGR Valves (2)
Has anyone been brave enough to blank off their EGR valves on 05-06 Models, & if so were there any noticeable improvements in performance? I've just bought the Blanking Kit (incl the excellent instructions & colour photos) from Britpart & everything appears accessible. 'Wonder how it might effect the MOT with emission readings.
Post #264073 Sat Apr 24 2010 5:21pm
AlexMckie
United Kingdom 2005 Range Rover Sport TDV6 HSE Rimini Red
Hi there,
Did my '55 plate and it was a little fiddly. My only word of advice is take your time and do not drop anything as
there are enough places to loose my whole socket set down there, and you don't want to be taking the sump shield off!!
There was a noticeable difference in pick up and overall very pleased.
Hope this helps.
Alex
Post #264078 Sat Apr 24 2010 6:50pm
bellautos
United Kingdom 2005 Range Rover Sport TDV6 HSE Cairns Blue
HI
You wont have any problems at MOT time with blanking the EGR valves.
Pete
Post #264133 Sun Apr 25 2010 9:34am
jbd-organ
Thanks to Alex & Pete. I've since successfully blanked them off & also found an improved pickup. Thanks again.
Post #264772 Fri Apr 30 2010 3:16pm
accyis
United Kingdom 2006 Range Rover Sport TDV6 HSE Zermatt Silver
Hi. Just wondered if this has altered your MPG's and If so by how much.
Post #264778 Fri Apr 30 2010 5:52pm
jbd-organ
It's early days yet to confirm mpg on the 'blanking', but the computer appears to be showing 25.7 mpg just undertaking local runs which is a healthy increase over about 24.0 I used to achieve, & that's with occasionally trying out the improved pick up!
Post #264807 Sat May 01 2010 11:41am
