![]() | Home > Technical > Front Brake Sensors |
julie Member Since: 27 Apr 2010 Location: glasgow Posts: 18 ![]() ![]() ![]() |
yes but alarm will beep non stop until you get sensors |
Jay Boy Member Since: 30 Aug 2009 Location: South Wales Posts: 119 ![]() ![]() |
Your parts dept at the dealers should be able to supply the sensors direct to you. put them on, JOb done no more noise.
martin g Member Since: 12 Feb 2008 Location: Somerset Posts: 14 ![]() ![]() |
Thanks ill see if I can get them tomorrow and try to get them fitted by friday if not will have to put up with the warning |
you can get gen parts on ebay much cheaper |
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 ![]() ![]() ![]() |
You'd have been ok doing 400 mls on them if the sensor just on.... if you cannot get the sensor no worries, and IIRC unplug it to silence the 'bong' until you get back |
