Home > Technical > Suspension has a mind of its own
RussRRS
United Kingdom 2006 Range Rover Sport TDV6 HSE Bonatti Grey
Sorry if this has been spoken about before, but i did look in the forum stickys but couldnt see the same problem im having.
w
Was driving home from the inlaws this eve and when i stopped at a set of lights the car lowered to access mode without any warning or dings or anything, the switch in the center console still showed normal driving height but i pulled over and it was definitely sitting in access. i held the switch and the car raised again with the normal dings, but as soon as i pulled to the next set of lights it lowered again. ended up driving home with it in access mode, but when i arrived home 20 mins later i put the parking brake on and the car raised into normal mode without touching a thing. ive since taken it out again for a test drive and she seemed fine. can this be a simple gremlin or the start of something major??
oh its a 56 plate HSE
cheers
Post #264184 Sun Apr 25 2010 6:49pm
MAW
Possibly a faulty height sensor - been through any surface water recently?
Post #264234 Mon Apr 26 2010 7:48am
RussRRS
Nah mate it's been in the body shop all of last week, oy got it back sat. LRA are with it now so gotta wait for them let me no the score
Post #264257 Mon Apr 26 2010 10:46am
MAW
Mine lost it's mind recently - there is a pic in my gallery.... LRA came out and replaced a height sensor and that sorted it - lets us know how you get on
Post #264264 Mon Apr 26 2010 11:28am
RussRRS
well LRA just left they recon it was a software problem so he has updated the system and recons that should be ok now, so fingers crossed as really cant lose the car this week as im stuck in bristol till thurs so the mrs is on her own, thanks for the info fella Thumbs Up
Post #264266 Mon Apr 26 2010 11:39am
Micrometer
United Kingdom 2010 Range Rover Sport Supercharged Java Black
The car was in transport mode (an air suspension ECU mode). When transporting the car drops to just above the bump stops so that the usual sinkage level of the vehicle does not slaken the ropes on the transporter when the vehicle is driven off the transporter then it needs to raise. SOmeone must have put the controller into this mode - it doesnt happen on its own!!! Trust me, i'm an Engineer!
Post #264592 Thu Apr 29 2010 10:01am
