![]() | Home > Maintenance & Modifications > Cordless Polisher............Any Good |
JC1 Member Since: 24 Oct 2009 Location: Berkshire Posts: 939 ![]() ![]() ![]() |
anyone used one |
npinks Site Moderator Member Since: 27 Nov 2007 Location: Watching Posts: 6716 ![]() ![]() |
I don't know..... But they have been chatted about on DW
Bradders Member Since: 08 Oct 2009 Location: Leeds Posts: 2515 ![]() ![]() |
I'd agree, I doubt any cordless polisher has got the necessary grunt to correct any paint but should be fine for applying polish or wax and then buffing up. FF 4.4 V8 Soooo looking forward to this bad boy
Thanks for the advice |
JimWD Member Since: 08 Jan 2010 Location: East Mids Posts: 9 ![]() |
Does it have to be Cordless?
NickM Member Since: 15 Feb 2008 Location: London Posts: 2995 ![]() ![]() |
If you get shown how to work with a rotary and a DA - you will see how hard work DA's are - and how they need 4 times as much hard work, and to be honest the results are not as good. My top tip, and doing this with 2 others on here - spend £200 on a really good Rotary - and as you only need to do a correction once a year....it's money well spent.
When you say you done 15 minutes detailing before you came in, what do you mean or what did you do in 15 mins. |
Because I'm keeping the car pretty clean each day - i use a detailing spray - like Dodo Red Mist Tropical, and just spray on and wipe off all over the car - it can be done in 15 mins - providing there is no dirt that can cause you to scratch the car - it works a treat - just light dust and grime from a days driving, comes off very quickly..... |
Cool, i thought detailing spray was just to be used in conjunction with clay, so is the dodo spray a polish |
You're right the lubes you get with clay are in essence detailer spray - but some detailers spras are just too good to use with clay...as good as Dodo detailer is I also like the Megs detailer - both cost about £10 and both work well, with the Megs being easier to use..... |
Nick, as/when you run out of RedMist, see if Alex @ Elite can supply you with some Zaino Z8.. I only use Spray Sealants like this as a weekly 'top-up' if you like after a proper wash.. ONR might be a nice system for you to look into if you like to wipe the car down after every use.. Optimal No Rinse - google it.
Thanks mate....will give it a try - got lots of Zaino stuff yesterday and Robbie that works next door, swears by the stuff - Alex was great when I popped round there and will def go back again next week and will def also try the Zaino stuff, as I do like to wipe the car down every day.......
