Home > Technical > HDC fault - it's not the battery!
jetblasters
2005 Range Rover Sport TDV6 Java Black
Just to repeat, it's not the battery - bought a new one yesterday (from Land Rover) and fitted. Felt very smug. Drove 10 mins down the road and the Christmas Tree lights came on the dashboard along with the two bongs of 'you have a problem' and then the impending frustration from me.
Right, anyone with any bright ideas? I had to drive 200 miles today and it did it on the way there/back too.
cheers,
Stuart
Post #264091 Sat Apr 24 2010 9:14pm
BigMart
I've seen it a few times before when the wheel speed sensors (abs sensors to you and I) cause this problem.
A quick check on the stored fault codes should point you to the right corner.
You may be lucky and the "apparent" abs sensor fault might be caused by a bad connection in the wiring to it.
They are usually connected to the vehicle with a plug and socket arrangement. You can experience road dirt/water etc in the connector.
You might be lucky but an abs sensor isnt a fortune to replace anyway.
MArt Jaguar XF 3.0D Portfolio
RRS TDV6 HSE 2006 , Zermatt , Gone
Post #264123 Sun Apr 25 2010 8:45am
jetblasters
Cheers Mart - do we know anyone in the South West London/Surrey/North Hampshire that has the computer that can check this for me so we know the right corner to check and that isn't a main stealer? It's an 05 plate die$el.
thanks,
Stuart
Post #264127 Sun Apr 25 2010 9:05am
jetblasters
it gets better and better, so in addition to this I now have 'Suspension Fault' and stuck in access mode. Censored .
Post #264560 Wed Apr 28 2010 8:40pm
jetblasters
update time:
First of all, thanks to this site, I have saved another fortune. The fortune that I saved I have invested in a Hawkeye unit - WOW! (more of that later)
Had compressor changed and now the suspension is happy again and I am happy my RRS doesn't look like a pimp mobile Smile
Using Hawkeye the reason I was getting the various warning messages is that I have a brake switch failure. That will be fixed next week, car has no other faults. Smile Sweet and no main $tealer telling me other things are wrong with it. If I get time I will write up a more comprehensive report on the Hawkeye bearing in mind I am not an engineer, just a geek.
Cheers,
Stuart
Post #264765 Fri Apr 30 2010 2:13pm
jetblasters
a little video abut this error and the Hawkeye.
Post #265379 Fri May 07 2010 7:00pm
