Home > Technical > REAR TYRE WEAR
wullie
Scotland 2010 Range Rover Sport 3.0 TDV6 HSE Alaska White
REAR TYRE WEAR
Hi Guy's
I have an 06 RRS HSE TDV6, I have 285 x 35 x 22 on it, the front tyres are wearing fine but I had to replace the rear, the last 2" on the inside is badly worn down while the rest of the tyre is only half worn, When checking the tyre it isnt all fured up like a tyre is when the tracking is out, the tread is flat and wearing perfect but for the last 2".
Any ideas Guy's could it be the rear suspension or do the rear bushes give bother?? Sad
PS WHAT TYRE PRESSURE SHOULD 22" RUN AT.
cheers
Wullie
Post #257140 Wed Feb 24 2010 8:54pm
PapaBear
2008 Range Rover Sport TDV6 HSE Zermatt Silver
Hi Wullie,
Sounds like the dreaded 'bush settling'. Check out this thread
http://www.rrsport.co.uk/forum/topic17268.html?highlight=
Getting a four-wheel alignment done is the next step, trouble is the vehicle should be put into 'tight tolerance mode' some kind of lock to the air suspension, LR dealers can do that, not sure about your average tyre depot though, so don't expect much change from £200 and LR contribution is unlikely.
Good luck! Thumbs Up
Post #263284 Sat Apr 17 2010 9:58am
wullie
Hi Papa Bear, thanks for the info will have to get this done by the dealers then. Confused
cheers
Wullie
Post #263687 Tue Apr 20 2010 6:35pm
NickM
Tyre pressure - 40 all rounds works well
Post #263690 Tue Apr 20 2010 6:37pm
A little on the high side Nick Confused 2005 Zambezi TDV6 - Gone but not forgotten
Post #263693 Tue Apr 20 2010 6:42pm
leedsunited
United Kingdom 2008 Range Rover Sport TDV6 HSE Java Black
I was told 36
Post #263695 Tue Apr 20 2010 6:49pm
NickM
Well 40 is what LR pump them up to, and my last set of rubber last 38K miles....still with 4 mm left on them....
Post #263696 Tue Apr 20 2010 6:51pm
I stick to 36 too and my last set lasted 20k. Nick may I suggest you actually drive the car and not do 10mph everywhere! Wink 2005 Zambezi TDV6 - Gone but not forgotten
Post #263699 Tue Apr 20 2010 6:58pm
wullie
Guy's
I set them at 40 psi all round and have done 2000 miles, seem to be wearing flat, still watching the inside of the rear tyres though until I get time to take it to LR stealer for tracking Confused Prob bit hard for front but I'll see how they wear set at that.
Wullie
Post #263700 Tue Apr 20 2010 7:03pm
NickM
Have I told you I get 200 mpg too??? Laughing
I swear the mileage is correct - even LPR couldn't believe it - Toyo Prox's best tyres ever....
Post #263704 Tue Apr 20 2010 7:22pm
leedsunited
Mine are at 36 and done 30K with a fair bit left
Post #263743 Wed Apr 21 2010 11:10am
