Home > Maintenance & Modifications > Rear headrest removal |
Endjin Member Since: 22 Jun 2007 Location: Aberdeenshire Posts: 2087 |
Press & hold the little button on the base of the headrest (where the pole enters the seat top) and pull the headrest up and out. At least that's how mine works. P.S. The button is only on 1 of the pole inserts on each headrest. 2013 Discovery HSE Luxury - 3.0 SDV6 - Santorini Black
Fri Apr 16 2010 6:48pm |
dazsear Member Since: 23 Nov 2008 Location: Lincolnshire Posts: 851 |
Yeah but when you get to the last bit of pulling out you have to push the button on the other side (almost hidden) to properly remove them.
Fri Apr 16 2010 6:51pm |
funnyguy1 Member Since: 18 Jun 2009 Location: Sun Valley Idaho Posts: 171 |
Got it!! Thanks!! Mike mike murphy |
Fri Apr 16 2010 10:15pm |
