![]() | Home > For Sale & Wanted > FS: OEM Side Steps |
diesel Member Since: 22 Nov 2005 Location: wakefield Posts: 39 ![]() ![]() |
Received mine today.
musher Member Since: 07 Feb 2010 Location: portsmouth Posts: 44 ![]() ![]() |
Slimer,
Slimer Member Since: 26 May 2005 Location: Nanny State Posts: 224 ![]() ![]() |
andyrrs, AjH 4.2, roverGP - As I've still had no response from you your steps will be going to the next three waiting. Could a mod please remove them from the sign-up |
Rob Powell Member Since: 24 Sep 2009 Location: Staffordshire Posts: 10 ![]() ![]() |
YHPM |
porsche2rrs Member Since: 23 Jan 2010 Location: London Posts: 10 ![]() ![]() ![]() |
thanks slimer. |
quantz Member Since: 05 Mar 2010 Location: Paris, France Posts: 476 ![]() ![]() |
Slimer,
impreza54 Member Since: 01 Apr 2010 Location: Antibes Posts: 9 ![]() ![]() ![]() |
Hello slimer,
thebiggy Member Since: 26 May 2007 Location: solihull Posts: 34 ![]() ![]() ![]() |
I need some new steps post to solihull thanks |
kevinlagan Member Since: 06 Mar 2010 Location: Bangor Posts: 44 ![]() ![]() ![]() |
Slimer ,
tweaky - how difficult were they to fit? Did you use the fitting guide on LR site? I find them difficult to follow without written explanantions. Maybe just me!! |
Tweaky Member Since: 16 Feb 2010 Location: Hampshire Posts: 32 ![]() ![]() |
I used the fitting instructions that came with them, pictures only. I would recommend looking at the pictures for a while before you start and get it straight in your head first, but it is not as bad as it looks. The only tricky bit really is getting the trim back on again with the poppers. Some of my original ones broke so had to use the new ones supplied which are of a different design (they work fine) but you need to dig out the originals first which seems a touch brutal. If in any doubt i would take it and get a local specialist to do it for you. |
thebiggy, kevinlagan - I need to check what's left in stock, will let you know
thebiggy - Please check your PMs
doc matt Member Since: 17 Jan 2010 Location: North Birmingham Posts: 7 ![]() ![]() ![]() |
I'm not too far away, maybe its cheaper carriage 2 lots in one and ill come over and collect. ![]() |
